ECVT optimal speed for mpg? At highway speeds
Discussion in 'Gen 5 Prius Technical Discussion' started by 2023p, Sep 13, 2023.
  1. 2023p
    2023p Member
    112
    66
    Here
    2023 Prius
    Is that thing or does the ECVT at highway speeds for example, always adjust the best possible rpm/mpg? Does this question even make sense?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Probably not.......since the WHOLE vehicle is theoretically optimized for fuel economy.
    TGrracie and 2023p like this.
  3. PickyAudioGuy
    PickyAudioGuy New Member
    Chicago
    While the car is maximizing MPG at all speeds I've found on my 2010 Prius that somewhere just above 40mph will achieve a maximum of gas mileage at a somewhat highway speed. At this speed the engine will not shut off completely and battery augments power when terrain changes. I can tell because the ECVT nearly maxes is gearing and the engine throbs just slightly (like too high of a gear in manual trans). The electric then adds the required torque to keep the engine at this lowest rpm. I find this works in fairly flat terrain and between 40-50mph. With the engine not shutting off the battery is maintained at a decent charge level.
    Don't know if the newer Prius will work this way but the gen3's do. Hopefully I'll find out how the gen5 Prime does this in the next year or so.
  4. Trollbait
    11,560
    The engine does have peaks at different speeds and loads where it is more efficient. The system does its best best to keep the engine at or near those peaks. That includes adjusting the eCVT ratio. You, however, have very little input in how the system does that. Controlling speed is about it.
    2023p likes this.
  5. Mendel Leisk
    38,726
    No. The faster you go, the worse the fuel economy, pretty much linear. There's some flatter spots, some thresholds, but not significant. One way to to improve mpg is to take (lower speed) secondary highways, stick to the limit.
    2023p likes this.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    The eCVT will always be in the optimal gearing.
    BUT, the drive modes will dictate how much electricity/gas is used when you are stomping on the gas pedal because throttle response is mapped differently in each drive mode.
    2023p likes this.
  7. Mendel Leisk
    38,726
    The PWR and ECO buttons change amount of gas pedal travel required to achieve a certain throttle opening, but that's about it. I played with ECO for about the first six months, then switched it off (went back to "normal"), and found the pedal response more to my liking, easier to modulate.
  8. David Rush
    David Rush Junior Member
    28
    17
    BC Canada
    2020 Prius Prime
    Agree. In EV mode, the slower you go, the further you can go on the battery. Air resistance is a proportion to the square of speed I believe, therefore energy/km is proportional to speed. Idling around is extremely energy efficient in EV. When running ICE, 40 - 50 Kph is best but it can take a long, long time to get places. Very important to regen brake and coast speed off when approaching a red light etc. Friction brakes are a total waste of energy.
    My Gen 4 Prime is rated at 40 km but I squeeze 62-63 out of it in the summer. 15% less in cold weather, another 15% less with winter tires and even less with the HVAC running. I take slower roads over faster ones and enjoy the view....
