(edmunds.com) Fuel Sipper Smackdown 2
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Aug 7, 2009.
  1. Tideland Prius
    16,155
    A lot can change in one year. In May 2008, we had the idea to bring four frugal, fuel-sipping cars together to determine which was the most fuel-efficient and the cheapest to run, and which did better in specific driving conditions. While the EPA's fuel economy estimates are a good guide for determining a car's overall thirst for fuel, we wanted to do our own controlled testing to see how different types of cars performed in the real world.
    Full Article
    Fuel Sipper Smackdown 2 Video
    Link to the 2008 Gas Sipper Smackdown
    Link to the 2008 Gas Sipper Smackdown Thread on PriusChat
  2. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    That's a good one! The Prius whupped 'em all by a fair margin in FE.
    Prius also has the most cargo capacity of all the cars tested here.
    I saw 3 more '10s today during an hour drive - 2 Blizz's and a Gray (Lots of Blizz's out there!). The more I see, the better. :)
  3. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    There were 3 of us at the same intersection today! 2 Silver and a Red. Sadly, I had just passed another (Black) just a minute earlier. 4 at once would have been truly amazing.
    Back on topic, gotta love those results... Prius - Jetta TDI:
    City: 48.7 - 31.6
    Highway: 47.4 - 40.6
    Back Roads: 47.2 - 41.2
  4. bwilson4web
    15,524
    What I especially liked was:
    My experience with after market tires strongly suggests anyone seriously measuring mileage needs to calibrate their trip meters. This can be done either using mile markers on a highway or a GPS. Regardless, it needs to be done.
    The second is the accuracy of the Prius MPG gauge appears to be a function of the driving style. My wife, Edmunds and even Consumer Reports have from their low mileage, a tendency to be in the 'red bar' part of the HSI. Speculation on my part, I suspect the cooled exhaust gas operation at high power settings may be associated with this error.
    There are two ways to measure fuel consumption: (1) mass flow, and (2) injector timing. I suspect mass flow measured fuel consumption is most impacted by cooled exhaust gas operation. My understanding is the fuel injector timing based scan gauge may be more accurate.
    NOTE:
  5. EVdriver
    EVdriver Junior Member
    39
    The lung-cancer factory has failed, AGAIN. :)
  6. syncmacd
    syncmacd Waxing is Relaxing
    SoCal
    "The Insight showed the limitations of its mild-hybrid design, as its air-conditioner does not work when its engine automatically shuts off at stoplights."
    OMG did they not think this was a slight design flaw? I have lights that do not change for almost 90 seconds. Admittedly in Southern California this is not as big of a deal (high temperature today: 85 F) but in places like Arizona or Las Vegas I imagine this would become uncomfortable quite quickly. Heck, even here we'll still get the occasionally 100 degree day.
  7. hill
    8,187
    Wow . . . I wonder how the poor TDI folks'll take this 'smack-down' ... sheesh ... even the guzzlin' Ford hybrid ate the TDI's lunch. Sure puts a different spin on some of those goofy TDI commercials showing that they get a bazillion mpg's above the EPA results.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The resident TDI folks are awfully quiet about this. Kinda sucks for them when the story they've been spinning gets blown apart so thoroughly. Emunds did what they could to throw the TDI a bone, but there's not any meat on it.
  9. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Maybe it can be a sticky for awhile and when needed to answer blah blah blah just point them to it.:D
  10. Tideland Prius
    16,155
    Remember that the Gen I Prius did this two. It was upgraded with the Gen II. The HCH-II was also upgraded to an electric A/C compressor (and it's also a better system than the Prius II) but I guess they cut corners with the Insight to keep the price down (The IMA has been downgraded a bit even though they say it's the 5th Gen as opposed to the HCH-II's 4th Gen)
  11. Celtic Blue
    2,224
    139
    Midwest
    What specifically about HCH-II's electric AC system is better than the GenII Prius' electric AC system? I'm curious, I haven't really studied either of the AC's.
  12. Tideland Prius
    16,155
    It runs off the engine when it's on so it doesn't sap power from the battery. This reduces energy conversion "losses". The Prius runs off the battery regardless of whether the engine is on or off so the battery will need to be "recharged" (so to speak.. i'm not saying the A/C drains the battery all the time) via the engine or regenerative braking.
    Of course this means that the HCH-II will still have the A/C load on the engine while the P2 and the P3 (esp. now that it's all beltless) will have more power going to the wheels.
  13. Celtic Blue
    2,224
    139
    Midwest
    Interesting, that would make it more efficient at times. But I wonder if there is any sort of persistent hit for whatever clutch/belt mechanism is running the compressor from the engine? It might be a small effect, but if it is always there it might offset or exceed the net of the conversion loss.
    I remember having an underpowered K-car with a problematic AC clutch decades ago (the shaft had been messed up by the previous owner, probably during an accident repair, so sometimes the clutch would stick and I would have to fuss with it.) I removed the AC belt except in summer.
  14. Tideland Prius
    16,155
    That I can't answer. Now with the new 3rd Gen's beltless engine, I wonder if it's more efficient because the engine has to work less to get power to the wheels (b/c there's less load on the engine now that everything's electric) and an even more efficient regenerative braking system setup will minimse the mileage hit because it can recover more energy braking at the same speed than a Gen 2.
  15. bwilson4web
    15,524
    You are very close because the relative energy demands of an electric versus a mechanical system:
    • electrical - the energy load is independent of engine rpm
    • mechanical - a variable energy load following engine rpm
    An electrical system will have an energy draw driven by the load and independent of how fast the engine spins. But a belt driven system, even with the clutch open, will have an energy draw proportion to the engine rpm. The bearings and belt flex will draw power in proportion to the ICE rpm all the time but under load, these losses become worse.
    A belt drive alone does not give one A/C system an advantage over another without considering the whole A/C system. The Prius New Car Features discusses the 2010 air conditioner:
    4,920 W - capacity
    240 W - power consumption (~1/3 hp)
    This is very efficient for an A/C system, which includes an advanced condenser with two distinct compressed gas flows.
    BTW, a belt drive has losses too:
    A Department of Energy study, ORNL/TM-2006/423, found typical Prius motor efficiency in the 90-93% range and it would reasonable to expect the generator efficiencies to be similar. A 2-5% difference in power transfer efficiency is pretty small especially when looking at a worst case 240 watts of the 2010 Prius.
    So as the vehicle speed increases, the A/C load as a fraction of total power remains flat for the electrical A/C but a mechanical drag makes a belt driven compressor have a linear increase in energy losses. This data suggests a Prius with the windows up and A/C running may have measurably better mileage than with the windows down. The return, highway data suggests this may have played a part:
    The Honda Insight showed an uncharacteristic loss of highway performance. Since they mentioned the heat in the City test, I suspect the mechanically coupled, compressor of the Insight might have been the reason for the dramatic loss of mileage. Now if the Jetta TDI had a better coupling mechanism or internal valving to reduce compressor load at high speeds, the data begins to make a lot more sense.
  16. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    Bob, could the Insight's decreased highway efficiency also be due to a 1.3L engine coupled with a CVT having to maintain higher RPM's to maintain speed?
  17. syncmacd
    SoCal
    Don't think Insight owners will be happy to find their insides are comparable to a 1st generation Prius...
    OTOH, the other day I parked next to an Insight, dark gray. Very attractive looking car. And 40 mpg is probably better than 95% of cars out there. There's nothing wrong with purchasing an Insight!
  18. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Hi Bob, I'm not sure if this is common on all vehicles nowadays, but the Jetta has a variable displacement A/C compressor that may help to reduce the load.
  19. bwilson4web
    15,524
    There are many possible sources of the lower Insight, highway mileage and the A/C was one. The Jetta TDI mileage improvement is disproportionate to what I would have expected and having the vehicle tuned for high-speed, highway driving would make sense including better accessories. But I am bemused at the prospects of Prius owners and advocates 'doing the engineering' for non-Prius vehicles ... in the absence of a test article. <GRINS>
    Speculations, hypothesis, wild *ss guesses ... these questions really need to be addressed by the specific vehicle advocates in their own 'backyard.' I mean really, a Prius guy trying to figure out why an Insight didn't get better mileage compared to a Jetta TDI? ... What is wrong with this picture?
  20. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Bob, the ScanGage use's mass air flow to determine MPG. So far on my 2010 the ScanGage has read around 2 MPG lower than calculated while my HSI display has been 6-7 MPG higher.
    Wayne
