Effects of Towing
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by EastR, Dec 12, 2024.
  1. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    PriusChat friends - my 2016 V three (55k miles) was recently parked in a private lot and was towed about 6 or 7 miles to a tow lot. I believe a T-style tow truck was used with back wheels up and front wheels down (car was parked head in). I couldn’t get any answers from the lot employees when trying to ask how/which truck was used on the car. It seems to run alright but I’m concerned the transmission could have taken a beating and see towing front wheels down is highly not recommended in the manual. Any advice on what to watch out for or if a mechanic can diagnose would be great. Thanks!
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,498
    5,814
    Texas Hill Country
    I would not worry about if it drives ok and will lock a front wheel in Park.
    I doubt they towed it front wheels down. First the car would have been in Park which mechanically locks the front wheels via the transaxle. It would have to be in Neutral to roll the front wheels. You need the car on to get Neutral.
    Tow truck drivers will sometimes drag the car out of a spot so they can tow it with the back wheels down. This is only a few feet and hurts nothing except a little tire rubber. Slamming on the brakes is worse.
    Typically they pull the car completely onto their bed.
  3. Leadfoot J. McCoalroller
    7,828
    7,294
    Pennsylvania
    2018 Prius c
    ^That.
    When using a spectacle lift and the car's drive axle is not immediately accessible, they just drag it out into the lane, reposition the tow truck and then pick up the car again the correct way for transport.
    Almost universal procedure, but I'm sure you can find somebody who failed towing school.
    The nice guys squirt some dish detergent on your drive tires to make them slide a little easier for that first move.
  4. Air_Boss
    Air_Boss Senior Member
    4,133
    1,152
    New Yawk
    Tire squeal gives up a repo in progress...
  5. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    They put the front tires on a 'dolly'; otherwise you could've followed the trail of rubber back to the tow yard and there would be flat spots on your two tires.
  6. EastR
    EastR Junior Member
    85
    Miami, FL
    2016 Prius v wagon
    Thanks that is good to know. Appreciate the guidance.
