Efficiency Tracking
Discussion in 'Prime Main Forum (2017-2022)' started by eric1234, May 14, 2021.
  1. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    Hi all,
    I just got a new RAV4 Prime SE. I also own a 2018 Volt.
    I have a question for the gurus here about efficiency Tracking:
    Of the many different efficiency tracking screens, is there a way to track the MPG of the gas engine alone? (I can't find one on my RAV Prime - but this is readily obtainable from my Volt):
    For example:
    I get into the RAV4P, and drive it 100 miles. The first 40 is all electric. The next 60 are HV operation. For the entire 100 miles, I use 1 gallon of gas.
    I understand that one way of looking at it is to say that I got 100MPG. (considering the electric powered distance).
    Another way is to say that I got 60 MPG (I went 60 miles for the 1 gallon of gas during the period of time that I used my vehicle as a "hybrid").
    Is there a screen that will show me the 60 MPG? Or will they all display 100MPG? Is there any way (on the Prius Prime, as a comparison point) to ascertain the actual mileage relating to Hybrid operation? (i.e. the 60 MPG)
    Thanks
    Eric
  2. HanS0lo
    HanS0lo Junior Member
    WA
    I don't think display 60MPG (in the case you made) is a option, but later down the road you can have educated guesstimate by using percent of miles driven on electric. So:
    Your "60MPG" = overall history MPG * (100% - overall EV driving ratio)
    (you can EV driving ratio in the trip information, I attached a picture below.)
    #2 HanS0lo, May 14, 2021
  3. Trollbait
    11,540
    The Prius Prime can't track HV miles separately, and the software for the EV % is from the Prius. It counts all miles with the engine off as EV. Even if those engine off times are when in HV mode.
    I would assume the Rav4 Prime is the same until there is proof otherwise.
