EGR bad- dealer ready to pounce
Discussion in 'Gen 3 Prius Main Forum' started by w2dzo, Jan 12, 2023.
  1. w2dzo
    w2dzo Junior Member
    NC
    All,
    Have a 2010 Prius, 209K - running good. Check engine light came on, p0401- took to dealer and they said EGR replacement- $1100- OK- just got another call and they think it would be best to replace manifold as well. total now up to $3400- I'm stunned- Someone tell me to pull it and go local - or bite the bullet?
    Thanks
    Floored in NC
    Tombukt2 likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    12,210
    2,152
    Durham NC
    Where in North Carolina are you I'm in 27243 in Efland The parts you speak of to buy for that vehicle You should be able to get the EGR cooler and valve off any car you want for near nothing like at LKQ If you really want a new EGR valve you can pay the couple hundred bucks or whatever I am not sure if they're a remanufactured units available other than Toyota and the exhaust manifold I have four or five sitting around here and get in touch when you get ready or maybe you're too far away I can make time to fool around with your stuff I don't generally do things like this but for somebody who's right here kind of local We could make it happen or not Good luck I wouldn't spend anywhere near that
  3. Tombukt2
    12,210
    2,152
    Durham NC
    Yeah your post doesn't your profile doesn't say where I'm in 27243 Good luck with your project I will be leaving for Sterling Virginia Friday morning and be back Sunday afternoon and then we'll be here a long time.919 892 0363 good luck
  4. Eddie25
    Eddie25 Active Member
    490
    207
    MI
    I wouldn't do that. It VERY likely just needs cleaned (the egr cooler, the egr, and the intake manifold). It's a DIY-able job as you'll see if you do some research on it. Even paying someone I'd be really hard pressed to spend a grand. Shop around for sure or get into it yourself maybe with the help of a handy friend. These cars are most valuable to people who can DIY when they get to that mileage.
  5. ChapmanF
    17,343
    Don't overlook opening up the EGR valve to check for mashed ski-jump syndrome.
    If mashed, it's easiest to replace the valve, unless you really want to try building it back up with a heated butter knife or something the way ozmatt did.
  6. Tombukt2
    12,210
    2,152
    Durham NC
    Yeah I've seen this business before you definitely replace that bad boy I don't think I'll be forced to do the butter knife trick they're plentiful around here and I guess now they're putting this same valve on Corollas It looks like.
  7. bisco
    51,151
    yank it and go loco if you can find a willing mech. shouldn't be more than a grande or so
  8. Grit
    Grit Senior Member
    6,452
    4,186
    Wilkes Land
    Diy in your own garage!
  9. Mendel Leisk
    40,582
    That’s the way to go; doesn’t need to cost a dime.
    And next time you’re car shopping, remember how Toyota didn’t want to hear about it.
    Merkey and Grit like this.
  10. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    It's a DIY job if you reasonably handy, 3 hrs tops and probably about 20 dollars in cleaning products.. Plenty of vids on you tube
  11. xliderider
    xliderider Senior Member
    8,056
    3,222
    Honolulu, HI
    3 hrs? I had a spare EGR cooler, EGR valve, and intake.
    It still took me 2 days. Some of the coolant hoses and clamps were a PITA to get to and remove. Not to mention the difficult to reach and remove nuts and bolts holding things together.
    Admittedly, I was taking it slow to make sure that I didn't break or mess anything up.
  12. Mendel Leisk
    40,582
    Breaking it up into two days is sensible too, say save the intake manifold for the second day. Or just do all the reassemble the second day. My technique with the cooler requires multi-hour soaks for starters: get it started asap, then deal with other components as it soaks.
  13. Noahdoge
    Noahdoge Active Member
    199
    140
    Mississippi
    Order this on eBay. Legit dealer, so make sure you’re ordering from Manhattan Beach Toyota. Find a local mechanic to you who has a good hourly rate and good recent reviews. I’d have them clean the intake manifold with specific instructions on the four small egr passages. If you can find one to also clean the egr cooler that would be even better.
    Montgomery likes this.
  14. rjparker
    rjparker Tu Humilde Sirviente
    9,594
    5,891
    Texas Hill Country
    There are advantages to using new parts. The intake manifold has been updated while the EGR valve is not always easy to recondition in the garage. The EGR cooler is difficult to clean and could be the root cause for your code. If the dealer is suggesting replacing all three parts with new, they are doing so to guarantee there will be no issues from the EGR system when they get done.
    If you're doing it yourself and have no real timetable, have no need for guarantees then cleaning it is the common solution.
