EGR Cleaning: What did I get myself into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Jan 1, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Happy New Year!
    Some of you probably already know that I bought a spare EGR assembly (EGR valve and EGR cooler) off of eBay. My Prius is approaching 120K miles (currently at 116K) and plan to swap the EGR assemblies at that time. In addition, I will be changing the plugs, cleaning the Intake Manifold, cleaning the EGR pipe, and changing the PCV. Anything else?
    What I didn't plan on dealing with was a completely clogged EGR cooler. The eBay vendor warranted the EGR for 30 days. It must have been salvaged from an oil burning 2010 that had a blown engine, LOL.
    IMG_20171230_125358345.jpg IMG_20171230_125419260.jpg IMG_20171230_130146512.jpg IMG_20171230_130214152.jpg IMG_20171230_130222709.jpg
    Montgomery, mjoo, qettyz and 4 others like this.
  2. Bay Stater
    534
    771
    Central Mass
    Before spraying part cleaner, did some dry cleaning.
    IMG_20171230_130513984.jpg IMG_20171230_131426676.jpg IMG_20171230_131436805.jpg IMG_20171230_131446953.jpg
    mjoo, qettyz, RMB and 2 others like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I bet you’re glad you looked before just installing ;).
    While you have some work to do, you’ll be ready for the install :).
    Good luck and keep us posted (y).
    milkman44, RMB and Bay Stater like this.
  4. Bay Stater
    534
    771
    Central Mass
    Sprayed the openings with brake part cleaner for a few rinses. Then filled the EGR cooler with cleaner and let it sit overnight.
    IMG_20171230_135547286.jpg IMG_20171230_145543269.jpg IMG_20171230_153208661.jpg IMG_20171230_153459583.jpg IMG_20171230_155514788.jpg
    qettyz, RMB and Raytheeagle like this.
  5. Bay Stater
    534
    771
    Central Mass
    All of the cooling ports were clogged! I had to find a ridge wire that would allow to push the sludge through the ports. Not an easy task.:mad: Eventually was able to open up all the cooling ports. Sprayed part cleaner through the ports to remove as much sludge as possible.:eek:
    IMG_20180101_114636474.jpg IMG_20180101_131837188.jpg IMG_20180101_131918818.jpg
    qettyz, RMB, m.wynn and 1 other person like this.
  6. Bay Stater
    534
    771
    Central Mass
    Now that all the cooling ports have been opened, time to start the Oxi-Clean (it's Oxi-Clean, not Oxy-Clean LOL:ROFLMAO:) treatments! I heated the Oxi-Clean solution before pouring it in. Let the 1st wash sit for 2 hours. Drained out the solution, wow, pretty dirty.:eek:
    qettyz, mjoo, RMB and 1 other person like this.
  7. Bay Stater
    534
    771
    Central Mass
    The EGR Valve still has sludge in it after several part cleaner wash soakings. Any advice? Thanks.
    I am trying Oxi-Clean to clean up the remaining grime.:unsure:
    mjoo, qettyz, RMB and 1 other person like this.
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    It’s cooked on carbon deposits, it’s a challenge :(.
    I wouldn’t worry about it if it isn’t thick;).
    Try scraping the surface and see how thick it is . If thin, I’d just let it be. Doesn’t need to be spotless, just better than what’s going in:).
    Good pics and progress (y).
    RMB, m.wynn and Bay Stater like this.
  9. Bay Stater
    534
    771
    Central Mass
    Thanks @Raytheeagle! I would like to think that my original EGR assembly still in the Prius is not that bad. The spare EGR that I am cleaning hardly allowed any fluid to seep through the other end when I started.:(
  10. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    It probably is, but you never know;).
    Remember, this spare is is going into dirty service and you’ll do this again (or at least I assume so given you bought a spare):).
    So IMO not critical to get it “spotless”;).
    Looks good though(y).
    RMB, m.wynn, Bay Stater and 1 other person like this.
  11. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Agree with Ray in that the carbon coking in the EGR valve is a non-issue. What's important is that the circuit will allow the exhaust gasses to move freely from the exhaust manifold all the way to the combustion chamber. Your valve and cooler are both looking excellent, IMO. Plenty good enough for me, even before the Oxi soaks! Nice work.
  12. ChapmanF
    15,614
    It would be cool to have a PriusChat Circulating EGR Cooler. Get a clean one from the last person, make the swap, clean up your old one, send it to the next person....
    -Chap
  13. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Already started in the Bay Area;).
    Excellent concept and idea (y).
    Montgomery, Sommer86, leeb18c and 5 others like this.
  14. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    That sounds great! Currently looking on eBay for an extra EGR setup to prepare for the upcoming job... currently at 97k and change... but they all seem overpriced.
  15. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    What price were you seeing?
    I paid $35 for the cooler a couple of years ago:whistle:.
    Thought it was a great price (y).
    Bay Stater likes this.
  16. m3pare
    679
    1,818
    SoCal (626)
    That's a fantastic price! I've read others have found a pipe/cooler combo for around $85-100. But at the moment, I'm seeing $60+ for the pipe and $150-200+ for the cooler. o_O
    Bay Stater and Raytheeagle like this.
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    I picked mine up locally at Rancho Toyota recyclers;).
    $35 for the cooler and $65 for the valve:).
    With the benefit of hindsight, I would have just gotten the cooler, but always good to have a complete swap ready for the next use(y).
  18. Mendel Leisk
    38,726
    I'm not sure about Oxi-Clean on the valve, since it is mostly aluminum. I'd stick to the Stainless Steel cooler with the Oxi.
    OTOH, I think the worst it can do is dull-grey the surface.
    It shines on the cooler though, just mix it as thick and hot as you can, dump it in with the south end plugged. Let it sit an hour or so, maybe run a thin wire through the passageways as it sits. Then rinse well with hot water and repeat.
    I'm thinking this purchased one might be in worse shape than the one on your car? But at least it reduces the car down time. Personally, daily use of our car is never mandatory, and I found the whole process was maybe 36 hours, just fiddling around, cleaning the one I pulled off the car.
    #18 Mendel Leisk, Jan 1, 2018
    Bay Stater and mjoo like this.
  19. mjoo
    mjoo Senior Member
    1,126
    1,316
    Michigan
    Yes, oxi-clean dulls the aluminum on the valve. I tried it. I don't think it will hurt the valve with a few soaks of Oxi but that's not proven yet.
    Why not get another 5k miles out of the cooler with a few extra soaks of oxi-clean? The EGR valve is much easier to remove compared to the EGR cooler.
    Next time I swap EGR coolers I'll try an Oxi-clean only cleaning. Oxi-clean does such a tremendous job that I wouldn't be surprised if it grabs all the carbon. That would be a huge time saver compared to drilling around the cooling fins.
    Mendel Leisk and Bay Stater like this.
  20. Mendel Leisk
    38,726
    Oh yeah, I'm enthusiastic about using Oxi-Clean on the cooler, and that was your suggestion, appreciate it. It took maybe 5~6 one hour soaks, and came out shiny-new clean.
    mjoo likes this.
