EGR Cooler screws
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, May 31, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    in spite of being careful, managed to drop 2 screws in the engine where they were impossible to find (i tried with flashlight, magnet, of course looking under car, and drove car back and forth with jolts to try to dislodge them)
    if someone might know the presumably metric sizes of these two screws (circled in green), would appreciate (the bolt on the top of the cooler and the stud at the very rear (closest to driver)) egr_cooler_diagram_156379_upload_2018-11-9_6-55-59_f1.png
  2. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    They are the exact same studs as the ones used for the exhaust manifold. Not sure on the dimensions, but I would guess M8x1.00 or M8x1.25.
    Stud = 90126-08052
    Nut = 90179-08101 (not 100% sure, multiple options are listed)
  3. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    I did the same thing, go to dealer parts they can order for you and they are dirt cheap. I got all new hardware for cooler, they were rusted anyways.
    mjoo likes this.
  4. Mendel Leisk
    40,574
    Ben Schneider and JC91006 like this.
  5. The Critic
    3,193
    2,327
    CA
    They are most likely stuck between the subframe and the steering rack. Don’t ask me how I know...
  6. Ben Schneider
    central florida
    i looked for hours... was able to seemingly get the cooler connected well enough for the short run. been driving it for a week or two
    i had called dealers and they had nothing in stock. got the usual, just give us your info over the phone etc... was expecting it to be expensive like everything else at the dealership... home depot has metric bolts for around a dollar each.
  7. Mendel Leisk
    40,574
    If you go that way, bring the cooler along. It seems to me you could connect the cooler to exhaust with a metric bolt, instead of the stock stud plus nut. You could get it slightly long, then put a washer or several behind the head of the nut to finetune the projection.
    And for the short bolt holding the cooler to the cylinder head, just a metric bolt, again maybe slightly long and count on a washer or several behind the head. Or just omit that bolt, and the nut going on the stud at the underside of cooler, the hard one to reach. The thing is plenty secure anyway.
    Still, if I was in your shoes, I would restore it to stock. I am a bit obsessive. The parts numbers (gleaned from my previous link):
    1. Top bolt: 91671-80820
    Pump Assembly Screw - Toyota (91671-80820) | Toyota Parts
    2. Back of cooler stud: 90126-08052
    Toyota Online Parts | Genuine Toyota parts | Toyota Parts Online product search | Toyota Parts
    3. Back of cooler nut: 90179-08101
    Manifold Nut - Toyota (90179-08101) | Toyota Parts
    They're all about $1 apiece. You could order through any dealership, would take a few days. If you can't have the downtime, use the Home depot bolt in the interim, for the back connection.
    Number 2 and 3 corroborate @The Critic's info, btw. (y)
    snead_c and Ben Schneider like this.
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,346
    Taylors, SC
    The screws are 8x1.25 with 12mm hex washer flanges. The stud is als8 8x1.25.
    Ben Schneider likes this.
  9. Merkey
    Merkey Active Member
    302
    275
    Birmingham, Michigan
    How do you know?
    Ben Schneider, RMB and Raytheeagle like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Experience is sometimes the best teacher;).
    Having done this job 8 times, I’ve grown my experience tool box some(y).
  11. Merkey
    302
    275
    I cleaned the EGR tube last week at 91000 miles. Some deposits, but not too bad. I used a nylon brush I bought at Walmart, but no soaking in Oxiclean or use of a solvent. Pretty simple, but don't know if I want to attempt the EGR cooler.
    Ben Schneider and Raytheeagle like this.
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    It’s not that bad;).
    Get the pressure washer out and it’ll make short work of the deposits:).
    Good luck (y).
  13. Borninblue
    233
    158
    Cleveland, Ohio
    Nobody “wants” to do the cooler. It’s necessary if you want the vehicle to last.
  14. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Egr cleaning fluid and then pressure washer = like new
    Merkey and Raytheeagle like this.
  15. The Critic
    3,193
    2,327
    CA
    What is EGR cleaning fluid?
  16. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    Air compressor or pressure washer will do the job.
    I used a few cans of spray break cleaner because I had an air compressor, I felt that I needed to have some liquid cleaner to go with it.
    If you have a pressure washer, I imagine, you could get it done with it alone.
  17. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    A pressure washer works great on the cooler and valve , what I use on the EGR pipe is acetone , got it spic and span ! I just zipped tied the cooler and the other parts to a chain linked fence and blasted away
  18. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Exactly that.
    It comes in a spray can
  19. Mendel Leisk
    40,574
    Maybe this:
    Diesel EGR Extreme Cleaner | Wynn's Europe
    And here's a comparison test:
    Still, pressure washers aside, I swear by oxi-clean. From what I've read here it's less effective as clogging gets more extreme, but still, worked fine for my low mileage case, and very thorough, shiney-new clean.
    I like too, that it's relatively benign, can be used indoors, water soluble. It takes time to work, but that's ok.
    farmecologist, mjoo and Merkey like this.
  20. frodoz737
    frodoz737 Top Wrench
    4,530
    2,437
    33
    While the other components are easy to clean...I will just buy a new cooler when the time comes. TDIs taught me that lesson.
