EGR is not supported by the OBDII?
Discussion in 'Gen 2 Prius Main Forum' started by 08PriusXSJ, Jan 10, 2017.
  1. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    Today, I used a scanner (Autolink AL319 by Autel) to check the M/I readiness for my 08 Prius. Supposedly, the scanner reports that EGR monitor is not supported (or N/A) for this car. This is true or need a better scanner to check the EGR readiness?
    Any comment and help would be appreciated.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    No egr monitor. I think. I do not recall seeing that on Toyota Techstream so if its not there it sure won't be on any other scanner.
    What are you chasing?
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Gen 2 Prius doesn’t really have EGR-system. It can achieve some (pretty small) EGR-effect by adjusting the valve timing but it doesn’t have the failure prone EGR-valve and passages.
    Prius tech training
