EGR Issue back again?
Discussion in 'Gen 3 Prius Main Forum' started by pierced, Dec 4, 2022.
  1. pierced
    pierced Junior Member
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Hi guys,
    Had my EGR cleaned just this January.
    Last night, heard a knocking sound just about after starting the car.
    Today, so far haven't heard the knocking sound again.
    However, after a 30 minute drive before turning off the engine I fully stepped on the gas pedal for 15 seconds and the engine rev is fluctuating.
    Is my EGR acting up again?
    PS: Tried to upload the video however I cant. Not sure why.
    Thanks!
    #1 pierced, Dec 4, 2022
  2. Mendel Leisk
    40,574
    One issue with professionals cleaning, you never know how thorough they are. Being paid by the hour, they will definitely want to rush, maybe cut corners.
    According the document you posted, in January you were already experiencing knocking at start-up; that was the complaint that lead to EGR being cleaned. This is could be due to coolant in the combustion chamber, leaking past the head gasket.
    It's my belief that carbon-clogged EGR components lead to head gasket failure. But cleaning the EGR components once the head gasket failure is started, will not turn back the clock.
    That said, 95k kms is very early for head gasket failure.
    #2 Mendel Leisk, Dec 4, 2022
  3. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Sorry, not following you. What is suppose the problem is? :(
  4. Mendel Leisk
    40,574
    Head gasket failure.
    pierced likes this.
  5. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Thanks! Well, if its a head gasket failure at least is more affordable than EGR replacement, correct?
  6. ChapmanF
    17,326
    No; a head gasket itself is not expensive to buy, but replacing it is a significant engine disassembly chore whose cost will often need to be weighed against the value of the car.
    It certainly isn't the kind of thing a person would leap into without being sure it is the issue.
    There are some tests that can help rule that possibility in or out. And if the symptoms you're having are an engine running at fluctuating RPM and making some rattling sounds, there are other potential causes to check for as well.
    Foxglove and Mendel Leisk like this.
  7. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    I hope it's not actually the head gasket. I will be contacting Toyota tomorrow again. Not sure if you guys are familiar with Toyota Relax?
  8. bisco
    51,140
    no, please tell us about it
  9. bisco
    51,140
    it is possible they didn't clean the 4 small intake manifold ports
  10. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Not sure what claims I can get.
  11. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Even if it's Toyota? Specially knowing of this models' common problem.
  12. bisco
    51,140
    do they know? most dealers here don't even know there's an egr problem, and toyota is not telling them
  13. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    I have spoke to them about it and they know of the issue.
    Mendel Leisk and bisco like this.
  14. Mendel Leisk
    40,574
    A couple of tests for head gasket integrity:
    leak down test: cylinders are pressurized one at a time, at top dead centre of compression stroke, with special gauge set. How well they hold pressure, and where leakage occurred are checked
    boroscope inspection of cylinders, while coolant system is pressurized. They look for coolant leakage into cylinders.
  15. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    Easiest way to check is to open the cap on your coolant resevoir on passenger side of engine compartment. If you here a sucking sound when you do that you need to monitor coolant loss. This indicates headgasket failure and if you're only driving around town and avoid driving in hot weather you can go years avoiding this relatively expensive repair.
  16. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Okidoki will do that today. Any time frame or anytime will do?
    I will try to ask Toyota about this when they contact me, right? A little bit technical for me.
    Actually I wanted to upload the video however it seems that an mov file or mp4 file is not applicable.
  17. PriusCamper
    12,048
    4,892
    If it makes a noise when you open it, that's the problem... I've saved huge amounts of time doing diagnostics with this technique. Literally a few seconds after someone arrives with a problem Gen3 prius the diagnostic is done and we both get on with our life.
    pierced likes this.
  18. Mendel Leisk
    40,574
    The usual way seems to be to register with YouTube (or other movie hosting website), upload your movie there, then link to it here.
  19. pierced
    50
    Norway
    2012 Prius+ MPV
    Business Edition
    Hope I did it correct. Hehehe
    Here it is.
    https://youtube.com/shorts/wPnHBz4sy5g?feature=share
    I checked dip stick this morning and no changes on level. The coolant is also on same level. Should I open it while the engine is ON and listen to the said sound?
