egr issues - revving and fumes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Jul 20, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    was finishing off some work from several weeks ago - had dropped bolt on the back of egr assembly and today was putting in replacement
    also opened the front (facing bumper) assembly to see if there was soot... it spun off and there were some ball bearing things that spinned. i did my best to push the top back but it kept spinning back and i decided to just push it in and bolt it down.
    now the engine is revving up and down (not too loud) and there is some minor fumes in the engine compartment.
    wondering if i mistakenly disconnected some hose or something the back or did not reconnect front assembly of egr properly 20190720prius_egr_156378_upload_2018-11-9_6-51-33b.png
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,522
    Bay Area, California
    2019 Prius Prime
    The black cap is on the egr valve and when sent a signal to move, creates a field that moves the valve.
    You just spin it down until you can thread the screws.
    The back stud and nut are important, so make sure they are on and secure.
    Good luck and keep us posted (y).
    JC91006 and bisco like this.
  3. Ben Schneider
    central florida
    thank you will give it a try.
    Raytheeagle likes this.
  4. Ben Schneider
    central florida
    seems to work. much appreciated.
