  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    I want to remove the EGR valve and cooler to give it a clean, what tools are best as no alot of space in there ?
    The hoses attached to the cooler ...is water going thru,what to do with it ? Just unclip them and let water come out ?
    Thanx
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
  3. Mendel Leisk
    38,881
    Ray what about the coolant? Did you drain first, or?
    @MeGuinness It's pretty much necessity too: to remove wipers, wiper motor/linkage and windshield cowl.
    Raytheeagle likes this.
  4. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Coolant was drained and windshield wiper cowling was removed. Coolant spillage was limited to 1-2 ounces if you cork the hoses, or 3-4 ounces if you just disconnect them and let them sit.
    Keep us posted @MeGuinness (y).
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    you can pinch the hose from reservoir to prevent it from being drained
