EGR stepper position vs ? to determine if EGR cooler is clogged...
Discussion in 'Gen 3 Prius Technical Discussion' started by Gliderguy, Nov 26, 2019.
  1. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    So playing around with some of the parameters I can see in Torque Pro, I came across the EGR valve stepper position. I have noticed that once the car is warmed up, it kinda sorta maybe correlates to the eco side of the Hybrid System Indicator screen. The EGR valve is closed right at the left side of the ECO are on the display, and is open fully as the display approaches the right side but a bit before we get into the PWR area. I am sure it is operating by some complex parameter based on temperatures, O2 sensor feedback, and throttle position and not some simple single parameter, but it got me to wondering.
    If we can correlate the EGR stepper position to some other driving variable (maybe it is an O2 sensor in the exhaust) , could we diagnose a clogged EGR cooler before a code is thrown based on the computer demanding a LOT of EGR valve opening because it is not getting much through the cooler? Any techstream savy people ever ponder on this one?
    I also thought the EGR stepper had something like 111 positions, but i have never seen mine go above 72 under any driving conditions. (2012 model 4).
    Thanks for any comments. Kinda new at the Prius thing, but am having fun with the technology available to explore it.
    Shig and Mendel Leisk like this.
  2. Mendel Leisk
    40,587
    I've always noticed, under moderate acceleration, I'll hear a buzz, somewhere. Actually seems to be coming more from passenger side, not sure though.
    Push the gas a little more or less and the sound goes away. Could this be the EGR valve? Not sure.
    FWIW I've also got a vague recollection someone tracked this down to a loose bracket; a coolant bracket near the front.
    I'll bow out, appreciate this is a more technical oriented thread, over my head.
  3. Gliderguy
    46
    Prescott Valley, AZ
    Doesnt hit the original question, but my car also seems to have a buzz in the passenger dash somewhere at certain engine revs or at certain textures of roads. I am not sure I am ready to try and track down a noise, but at the right frequency of either engine or road texture, it gets moderately loud. the way the stepper motor works I don't think you would be hearing a buzz, it seems to be more of a multi-turn screw drive to actuate the valve.
  4. ChapmanF
    17,355
    Regarding the original idea. you might want to tag on to this thread, where we've been talking about it before, so any information gathered is findable in one place.
    So far, it seems the idea might be promising, but we would need a lot more reported data, especially from cars whose EGR occlusion status is known, to be able to say whether it will really be a valuable test.
    Mendel Leisk and Gliderguy like this.
  5. Gliderguy
    46
    Prescott Valley, AZ
    Well, I just need to know what data points to track. I JUST cleaned the EGR cooler and pipe two weeks ago. Have not done the intake cover yet, but I understand it is a cakewalk compared to the cooler.
  6. ChapmanF
    17,355
    Why not carry on the conversation on the existing thread, so it benefits others who look there?
  7. Mendel Leisk
    40,587
    Definitely do the intake asap, it's defeating your EGR efforts, untl all it's EGR passages are cleared.
    m.wynn, Raytheeagle and frodoz737 like this.
  8. frodoz737
    frodoz737 Top Wrench
    4,536
    2,438
    33
    No one's come out with a good EGR delete kit yet? (for off-road use only ;))
  9. ChapmanF
    17,355
    Kit comes complete with a spare head gasket?
    Mr. F, m.wynn, Ed Beaty and 3 others like this.
  10. Mendel Leisk
    40,587
    Letting it get carbon choked IS an EGR delete, and all that gets you is elevated temp and aforementioned head gasket failure.
    m.wynn, Raytheeagle and mjoo like this.
  11. Gliderguy
    46
    Prescott Valley, AZ
    Will move to the other thread if I have anything else, but my understanding of the head gasket problem is the "almost" delete of the cooler where it shoots some 1200 degree not-very-cooled air into the intake, and the ridiculous net intake temperature causes dieseling, and BOOM, no more head gasket. If it were totally blanked off I don't think we would see the gasket in jeopardy. If you wanted to do a delete, all it would take is making a "blank" for one of the gaskets. Not that I am recommending that, but I suspect the headgasket would be happier compared to an almost blocked cooler.
    If a moderator thinks this should be merged into the existing topic, I am totally onboard with that.
  12. Perl1947
    Perl1947 Junior Member
    46
    Israel
    Prius 2011 shaky on idle engine, egr?
    I have removed the egr motor,only the black portion of egr valve.
    With the connector still attached.
    And started the engine. It sounds normal.
    Probably complete egr cleaning is needed.?!
  13. Mendel Leisk
    40,587
    How many miles?
  14. Gliderguy
    46
    Prescott Valley, AZ
    Cannot really tell much from that. I have watched the stepper motor positioning on the Torque app, and 1) the EGR does not open until up to temperature (around 155-160 degrees engine coolant temp) and 2) you need to be cruising down the road with the bar at least getting into the ECO zone before it opens. My EGR valve is pretty much fully open before I get the bar into the CHG zone. A rough idle might indicate an EGR valve that is at least partially stuck open.
  15. Gliderguy
    46
    Prescott Valley, AZ
    Should add that just removing the stepper motor assembly, I am not sure that would force the EGR valve closed and smooth out the idle as you seem to be describing.
  16. Perl1947
    46
    Israel
    Hi
    The valve is working smoothly not stucked
    At all.
    after reassembly the shaking began.
    So I removed the cover again .and assembled
    Egr stepper
    While holding the magnet in closed egr
    Position.
    Than battery was disconnected and reconnected.
    And magiclly.all is ok.
  17. Perl1947
    46
    Israel
    Problem related to stepper motor
    Realigning.
    Don't understand why the stepper
    Must be realligned .
    I don't have torque pro ,so must obtain
    This application.
  18. Mendel Leisk
    40,587
    Reading along, I'm thinking it's best to leave the valve intact when cleaning. You can clean the passages and the valve without disassembly. It's a little awkward but doable.
    Perl1947 likes this.
