EGR system clean!
Discussion in 'Gen 3 Prius Technical Discussion' started by ChaseE, Jan 7, 2025.
  1. ChaseE
    ChaseE Member
    66
    33
    29
    Oregon
    Welp, thanks to everyone's advice since I just got my 2015 V (105k mi) I decided to tear everything down...and boy howdy I'm glad I did! The PCV valve was stuck, throttle body had a small puddle of oil at the bottom of it, the intake manifold was nasty, intake valves had oil on top of them, and the walls were caked. EGR valve was the same and you could barely see the shop light through the cooler.
    The demon bolt only took 5min to deal with thanks to @ASRDogman @Mendel Leisk @rjparker advice, and despite not having a T8 socket my 6mm hex worked fine.
    Used Purple Power and hot water with a fabric gun (5000psi), some heavy duty bristle brushes and pipe cleaners, then sprayed it all off and dried. Replaced PCV, transmission fluid (was BLACK), are replaced inverter coolant (accidentally, opened the wrong drain plug not paying attention!) Took about 6hrs to do everything, now I just have to finish putting everything back together tomorrow.
  2. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Nicely done. Wait, no oil catch can In stall?
  3. ChaseE
    ChaseE Member
    66
    33
    29
    Oregon
    I thought about it, but I think if I inspect the PCV and EGR every 25k miles I should be alright.
  4. Mendel Leisk
    40,457
    Good job. Cooler looks very clean. Best assessment is shining a light in from the near side.
    Torx socket sets are inexpensive; I’d get one. Studs on the intake manifold are E6. Torque values for everything in the repair manual excerpt attachments, in top link in my signature (on a phone turn it landscape to see signatures).
    quality oil catch can(s) will help with the intake manifold sludge pool.
    #4 Mendel Leisk, Jan 8, 2025
  5. ChaseE
    ChaseE Member
    66
    33
    29
    Oregon
    Everything but the wiper motor and top cowl is buttoned up, ran in maintenance mode and everything sounds good...unfortunately as I was topping off the radiator fluid so I could burp it from what leaked out the coolant lines, right at the plastic seam point where the full line is on the radiator reservoir, coolant started leaking from the back. Auto parts store down the road actually has a reservoir in stock so I'm going to pick that up and I guess drain and fill that side of the system as well!
  6. Mendel Leisk
    40,457
    That's odd, for it to start leaking out of the blue. I'd double check where the coolant's coming from.
    In my second down signature link, more EGR tips, there's a suggestion for avoiding coolant leaks: basically drain a couple of quarts into a clean container before disconnecting the cooler's coolant hoses. Then the system's more or less dry, nothing spills. Also, no need to disconnect throttle body coolant hoses, they have plenty of reach.
    (To see signatures on a phone turn it landscape)
    #6 Mendel Leisk, Jan 8, 2025
    Brian1954 likes this.
  7. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Inspections won’t clean any build up after 25K. Hang out here long enough and you’ll see.
  8. ChaseE
    ChaseE Member
    66
    33
    29
    Oregon
    it was literally a leak in the back corner of the reservoir...got a new one installed yesterday and holds fluid fine, ran the bleed proceedure and no lights or temps past 204F.
    Yeah I just mean to remove the PCV and intake manifold after 25k to see if there's enough gunk buildup to warrant cleaning everything again...if there is, I'll just do the same thing. Now that I know what I'm doing and don't need to reference diagrams and youtube videos every minute it will probably take less than 6hrs to tear everything down, clean, and reassemble.
    Updating profile pic, got replacement wheel covers a couple days ago and sprayed plastidip on them, looks much better imo.
  9. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Now that’s the right thing to plan for. I had the egr circuit clean up at a meet up and with 240K miles, no knocks or misfires since. No cleaning after doing it at 90k miles do the catch can should differ the next cleaning. Hope yours will last long as mine (y)
  10. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    Did u clean the 4 tiny egr passages on the intake manifold?
