EGR Valve and cooler
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Potorap, Oct 1, 2020.
  1. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    My wife’s 13 PIP 205k miles, felt like I should do some serious preventative maintenance. Removed,cleaned, and reinstalled. It was not as difficult as originally thought. I can feel a difference in power and response. Other maintenance performed.
    1. Drain and refill radiator and inverter.
    2. Replaced water pump and t-stat.
    3.Drain and refill transmission fluid. 4.Replced front brake pads and turned rotors.
    5. Oil and filter change.
    49,401
    wow, well done!
    any idea what % clogged it was?
  3. techie47
    techie47 Junior Member
    Philadelphia
    2015 Prius Plug-in
    Potorap, you are the man!
    Potorap likes this.
  4. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Was there any major maintenance done before 205K ??
    Potorap likes this.
  5. Mendel Leisk
    38,664
    Yeah auto-exposure makes it a black hole in the pic, hard to tell. With a phone camera, tap the black hole, should brighten it up.
  6. Potorap
    345
    148
    Pahrump, Nv
    Well, I must say I was pleasantly surprised the cooler was not that plugged. About 157k of HV miles, I would say 50%. It cleaned up pretty easily. I have seen plugged solid coolers. I thinking mostly highway driving is the reason for the condition.
  7. Potorap
    345
    148
    Pahrump, Nv
    Thank you. It was quite enjoyable doing the work.
  8. Potorap
    345
    148
    Pahrump, Nv
    No Sir. I was actually concerned by it. Tires, oil changes, 12v battery, and gas.
    Yea Right likes this.
  9. bisco
    49,401
    i wonder if that makes a case for higher miles being better for the egr?
    i have 20k, and am afraid to look at it
  10. Mendel Leisk
    38,664
    Odo miles or approx engine running miles?
  11. bisco
    49,401
    historical hv miles. engine running is some percentage of that, like any prius
