Ejecting CDs with Power Off
Discussion in 'Gen 2 Prius Main Forum' started by rslitman, Mar 4, 2008.
  1. rslitman
    rslitman Junior Member
    Near Philadelphia
    2022 Prius
    My Prius is still new, and I'm still getting used to some things about it.
    I've finally started using multiple slots on the 6-CD player (which I understand is called a "changer" because it has that 6-disc capacity). Because of habits left over from my old car, I don't try to eject any of the CDs (regardless of how many I have in there) until I've turned off the motor. However, I don't appear to be able to eject CDs unless the motor is turned on.
    Is this true? If not, can someone please walk me through the steps of doing this?
    Thanks in advance.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The motor doesn't have to be on, but you do need power to the CD changer. It doesn't have a hand crank. If you need to eject without starting the engine, press the power button once without pushing on the brake. This will bring the electrical system online in a mode similar to ACC in a normal car.
    Tom
    steveinsaugus likes this.
  3. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    Caveat:
    Do not forget to turn the car off when finished!!!
    Bad things happen.
    You've been warned.
