El Grande horns
Discussion in 'Prius v Accessories and Modifications' started by Dan H, Apr 24, 2025.
  1. Dan H
    Dan H Member
    49
    28
    Miami FL
    2015 Prius v wagon
    Another thread inspired me to do a horn "upgrade". Instead of the Toyota premium horns, I went with the "FIAMM 74100 El Grande" set from Amazon. They are dual tone and much deeper sounding than the stock horns on my 2015 v. I guess the deeper sound is considered "premium". The install was a very easy swap and I didn't have to remove the emblem for access. The existing one wire plug just connects onto the blade terminal of these. I have always considered the stock horns to be very loud and adequate, so I wondered how much louder these would be given that they are much bigger and have a horn shape. IMG_20250424_123321.jpg
    I must say, though the sound is a lower frequency, they do not sound louder and may not even be as loud. This is according to my highly uncalibrated and untrained ears. The stock horns seem more "aggressive" or "frantic" compared to these. I did use a db meter phone app and both the El grande and stock horns read 89db from about 4ft away in front of the car. Given it's a phone app, that reading could be meaningless. But from in the car, the stock horns seem slightly louder to me. So I'm wondering if I should return these or look into a 3 or 4 horn setup just for fun. Maybe add a relay and the originals back in to get a 3 tone setup. Anyone else install more than 2 horns?
    Here is a recording, taken from the same distance away, of the stock horns and then the El Grandes.
    It seems you cannot attach an audio file or video file but you can attach a .zip. Here is a zipped mp3. Let me know if this doesn't work
    #1 Dan H, Apr 24, 2025
  2. Tombukt2
    Tombukt2 Senior Member
    13,738
    2,486
    Durham NC
    The best horns I've found and I've installed are from a 99 taurus V6 car dual fiamm from factory. Loud. Free. Even bracket worked in Corolla and in Prius.
  3. Dan H
    Dan H Member
    49
    28
    Miami FL
    2015 Prius v wagon
    Okay, I tested the new el grande horns with an Amazon dB meter. (Danoplus gt1355B) At 6 inches from the bumper I recorded 122.2 dB with the meter set on "A" "Fast" and 93.8 dB at 30 ft. When set to "C" "Fast", it recorded 121.5 dB at 6 inches and 95.7 dB at 30 ft. So I guess that's pretty loud and cell phone apps are worthless. I haven't tested the stock horns since I removed them before I got the dB meter. The install is really easy so I may put them back in and test them to find out which ones are really louder.
  4. Marguerite14
    Marguerite14 New Member
    singapore
    Your observation with the dB meter is consistent with what others have found — lower frequency doesn’t always mean louder, just a different tonal character. Sound perception is very subjective, especially in an enclosed space like a car cabin.
  5. Tombukt2
    13,738
    2,486
    Durham NC
    I'm sure there is a site or some place where all this information has been printed stored and whatever companies like stebbel that make the Nautilus horn for boats and Lionel that make trains for horns and I would think all this stuff is pretty readily available I have buddies locally here in the Carolinas with Lionel train horns on their pick them up trucks.
