Electric mode not engaging sometimes...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hellochicken, Jul 28, 2018.
  1. hellochicken
    hellochicken Junior Member
    31
    los angeles
    when I drive my gen3 Prius around town, someitmes I would notice that the Electric motor doesnt seem to engage when I feel like it should. Example: driving around town at under 35mph, while practicing the good fuel efficiency techniques. Sometimes it works, someitmes it doesn't, sometimes the electric mode light goes on when I'm finally stopped, and someitmes it doesn't go on at all, despite having at least half on my hybrid battery level. i'm also averaging around 30mpgs in city driving, and I think it's due to the electric engine not engaging.
    When I drive Freeways, all seems to work fine, and I average anywhere between 45-50mpg, depending on hills and whatnot.
    I fear this will be a costly issue....
    any ideas?
    49,507
    could be your hybrid battery going south. how many miles on her?
    hellochicken likes this.
  3. hellochicken
    31
    los angeles
    91k miles. I imagine that's pretty low for the hybrid battery to go bad already...
    But IF it is the hybrid battery going bad already, aren't hybrid battery replacements pretty costly?
    49,507
    around 3k, but you have 10/150 warranty.
  5. hellochicken
    31
    los angeles
    OH! I didn't know about the battery warranty - that's good to know! I actually bought this car used, although it only had 15k miles on it when I purchased it...
  6. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Ev won't engage is the battery or inverter is too hot, too cold, or some other reasons.
    Usually in the summer
    So it's normal, I think
  7. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    If you parked it under sun for couple of hours during triple digit heat and drive without AC on, EV may not engage as hv battery is beyond hot to even charge and discharge so ice stays on.
    Raytheeagle and RMB like this.
  8. FuelMiser
    FuelMiser Senior Member
    1,300
    888
    Monument, CO
    Can you select the Energy Monitor on the big display (I think you press the "Car" button) and watch whether the electric motor powers the wheels? This may not be what is actually happening, but this is what the computer is thinking what should be happening.
  9. Elektroingenieur
    2,515
    3,259
    Three Touring
    As @4est and @grid kindly mentioned, it may just be the warm summer weather. The temperature of the hybrid battery and the demand for energy for air conditioning can both affect how much the engine runs.
    If the hybrid control system detects a malfunction, it stores a diagnostic trouble code (DTC) and almost always turns on the master warning light (red triangle). I’d suggest confirming that the master warning and malfunction indicator (check engine) lights both come on briefly during the lamp test when you start the car and then turn off and stay off. If the warning lights are working as expected, just keep on cluckin’.
    If you or a friend has a Toyota Techstream diagnostic system or third-party equivalent, you could check for stored DTCs. With only the behavior you’ve described, however, I wouldn’t consider it worth paying a diagnostic fee to have a dealer or independent shop do this for you.
  10. hellochicken
    31
    los angeles
    Thanks for the responses yall!
    Yes, the master warning and check engine light both come on briefly at startup. So based on what yall are saying, and what I'm noticing, I guess I'll stop worrying about it for now.
    Elektroingenieur likes this.
  11. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    Allmost forgot, the first couple of minutes after startup when ICE goes off as you drive, ICE will come back on and will stay on a bit as you begin to accelerate so engine can reach operating temp. Mine takes about 15 minute of highway driving for engine temp to be at 200-ish degrees- normal engine temp.
