Electric Motor Coolant Canister Dented
Discussion in 'Gen 2 Prius Technical Discussion' started by thedudeman, May 14, 2012.
  1. thedudeman
    thedudeman New Member
    US
    Hello, as you can see from the pics, the Coolant Heat Storage Tank Assembly (I didn't name it :)) for the electric motor has been dented from a wreak. Is it safe to use the canister or will it have to be replaced? If it needs to be replaced, where would you recommend I order this from? Thanks! This is a 2007 prius.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    It looks okay. Basically, you have nothing to lose by trying it out, because it is easy to get to if you want to replace it. Salvage are hard to come by, because most junkyard cars are similarly damaged in the front, so expect to pay at least a few hundred for a used replacement. New, they are $1000 +/- if I recall correctly.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Check the pump as well, which is on the other side of the tank. They are also often damaged in a collision.
    It's also called a coolant storage thermos.
  4. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    Just a quick fyi. That tank is for engine coolant storage. Nothing to do with the electric motors that propel the car. I agree you should try it. If it doesn't leak its probably OK.
  5. Mike500
    Mike500 Senior Member
    2,593
    764
    Take your finger and run it over the area around the bend. As long as the bent area is "radiused," and there is no crease that ends in a sharp point, you'll be just fine.
    The tank has to be a "soft" anealed stainless steel for it to be deep drawn to make it. No "point" crease means that the material has not been strained to the point of "separation" of the alloying "crystals" in the stainless steel.
    A "point" crease creates enormous tension on a pinpoint. This pinopint results in the separation of the crystals often known as "metal fatigue."
    If there are no "point" creses, the tank will be long lived.
