Electric Motor (in trunk space) runs after shutdown
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by BGSD4149, Nov 19, 2016.
  1. BGSD4149
    BGSD4149 New Member
    San Diego
    2016 Prius c
    Bought my Prius C one week ago! 1st off, love it! It drives quiet, is easy to park (I live downtown). This morning, I drove the car for 45 min & parked it in the garage. Around 3PM, I noticed an electric motor (Fan?) running underneath the trunk space . Is this normal? I verified the car was turned off (ignition-ish switch). Checked again around 4PM...the back-fan was turned off. This is the 3rd time this has happened.
    Also noticed every morning, when backing out, ICE turns on immediately upon backing out. Is this due to the Prius C's hybrid Synergy Drive configuration?
    52,390
    congrats and welcome! it's just an emission check, no worries. it can be disconcerting though!:eek:
    the ice always starts within so many seconds of putting the car in ready, depending on outside temp. if it's warm enough, you can press the ev button and keep the engine off for a short while.
    BGSD4149 likes this.
  3. blackbelt
    blackbelt Junior Member
    Saxonburg PA
    2014 Prius c
    What yo may be hearing is the cooling fan for the traction motor battery, which is located under the rear seat.
  4. fuzzy1
    10,603
    This is the 3rd time that you caught it in the act. It happens after every time you drive it.
    Somewhere in the Owners Manual should be a listing of the odd noises the car makes. This one is an evaporative emissions system check. It happens a certain number of hours after it was shut off, and lasts only a few minutes.
    BGSD4149 and Mendel Leisk like this.
  5. BGSD4149
    BGSD4149 New Member
    San Diego
    2016 Prius c
    Aside from this minor issue...I love my new car :D
  6. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Read the owner's manual. It specifically states the car makes noises after shutdown..
    XT830C ?
  7. Mendel Leisk
    41,901
    Last question first: I would think so. My 2010 Prius ALWAYS starts the engine, within 15 seconds of startup, and runs for maybe 5 minutes minimum, before getting into any engine shut-down behaviours.
    The 2016 regular Prius are a different case, they purportedly will leave the engine off at start up, maybe dependent on ambient temps.
    Regarding the noises when the car's off, there are some things happening a while after the car's been shut down. This is from page 16 of the 2014 Prius c Owner's Manual (happen to have that year's pdf):
  8. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    This
    iPhone ?
  9. Mendel Leisk
    41,901
    That'd actually be good, I suspect it can be slow-death for the hybrid battery: a hot car parked in a hot garage in summer. Would help if the hybrid battery vent fan could emergency-run for a minute or two. But I don't think it can.
