Electric motor noise of gen 3 vs gen 4
Discussion in 'Gen 3 Prius Technical Discussion' started by meeder, Jun 7, 2021.
  1. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Did anyone compare the noise of the electric motors between the gen 3 and gen 4 Prius?
    To my the gen 3 transaxle seems to create more electric motor "whine" when accelerating gently than the gen 4. I am not talking about full throttle max rpm accelerating but normal accelerating where you keep the gauge at the top end of the ECO area.
  2. Mendel Leisk
    41,377
    The 4th gen transaxle is a complete redesign; wouldn’t be surprised. 3rd gen has everything along a single shaft with all the gears and goodies. 4th gen has two side-by-side shafts.
    meeder and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Yes, the Gen 4 is quieter in that regard, possibly because of that redesign Mendel mentioned. Also, MG2 is smaller and has less torque but spins faster in the Gen 4. That could be a factor.
    meeder likes this.
  4. meeder
    239
    163
    Thanks for the info. The higher rpm of the electric motors cause it to make a higher pitched noise which is easier to isolate I guess.
