Electric Motor Noise Under Exhaust Pipe
Discussion in 'Gen 3 Prius Technical Discussion' started by berryman, Mar 2, 2011.
  1. berryman
    berryman Junior Member
    55
    Southern California
    Just walked by the back end of my new Prius III and heard what sounded like a electric motor running from the general area of the exhaust pipe at the right rear end of the car. This was about 5 hours after I last drove it.
    What am I hearing? Does it have anything to do with either battery?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    It's normal, it's the exhaust fuel evaporation leakage check and is mentioned in the manual... Enjoy your Prius :)
    Found this right here on Priuschat:
    http://priuschat.com/forums/gen-ii-prius-main-forum/73381-car-off-but-noise-coming-near-back-passenger-tire.html\
    Also, moving to the Gen II forums since your profile says you have a Gen II, not a Gen III (which is where you posted your question).
    Edit again, oops, saw you said now it was a Prius III but assuming you did not update your profile. Nonetheless, it is still normal for your car to be performing this noise. It's the vapor recovery system...
