electric motor running
Discussion in 'Prius c Technical Discussion' started by novaz, Oct 24, 2017.
  1. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    After having parked my C for 3-4 hours I walked past it and heard an electric motor running it was coming from rear of the vehicle and lifting the trunk it sounded as though it was coming from HV Battery area would this have been the fan for the filter.
    49,492
    pollution check, nothing to see here. scary though, my first time.:p
    the cooling fan does not run when the car is off.
  3. fuzzy1
    10,170
    Did it stop on its own accord, within a minute or two? It was likely the evaporative emission control system. Check your owner's manual for the list of noises the car makes.
  4. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
  5. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    are you saying that the car was switched on as I had already left keys indoors on "where are my keys hook "
  6. bisco
    49,492
    no, i'm saying it can't be the cooling fan if the car is off. so it's the evap check fuzzy mentioned above.
  7. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    sorry if my explanation was not clear the car was switched off and left for a few hours the keys were not present in ignition
    Thanks for replies
  8. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    ok I did not realize that was a function on the car
  9. bisco
    49,492
    no one does, until they hear it. it's uncommon to happen to be in the area when it happens, because it's so long after shutting down.
  10. novaz
    novaz Junior Member
    47
    arizona
    2015 Prius c
    Thanks I appreciate your time
  11. bisco
    49,492
    pleasure.
