Electric motor stopped - 2 orange warning dashlights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by morrownz, Dec 19, 2022.
  1. morrownz
    morrownz New Member
    New Zealand
    Feel free to bring any and all advice and insults, I no doubt deserve them.
    The two dashlights in the photo appeared approximately six months ago, the car has run fine otherwise.
    I have also included a photo of the message displayed in japanese that my main panel has been locked to since that fateful day. If anyone here is fluent I would be most grateful for a translation!
    My sincere thanks to all of you and Happy Holidays. 20221209_214650.jpg 20221027_200939.jpg
  2. Tideland Prius
    16,445
    The message just says
    "Check Hybrid System. Please stop at a safe place"
  3. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    I'll have to have my brother look He's fluent and some Asian languages maybe there's some Asian people that lurk here. Have it's been running good for 6 months and been getting reasonable gas mileage that's probably something silly like the catalytic converter code the threshold code things like that If you are in Asia I would think getting a tec stream scan would be pretty easy and not have to be done at a dealer I would hope. Good luck
  4. Mendel Leisk
    40,586
    Tombukt2 likes this.
  5. Tombukt2
    12,214
    2,155
    Durham NC
    Yeah I guess that's about the only message this car has is check hybrid system blah blah blah want to say that in some Asian person wing in and say it says completely the opposite come to think of it I don't think our Gen 3 is ever said much of anything else and I think that was because the door was unlatched. I think it's interesting that they always want me parked on level ground and checking the hybrid system.
  6. ChapmanF
    17,348
    I see a check-engine light, an electronically-controlled braking ((!)) light, a seatbelt warning light, and the master warning triangle.
    That's three warning lights by my count (plus the seatbelt light, which I assume to mean just that you were daredevil enough to take a photo while not strapped in).
    Have the other three, plus the "check hybrid system" message, all been there for six months?
    The trouble codes responsible for those lights being on can all be read with a suitable scan tool. It may also be possible to read the codes behind the ((!)) light—but not the others—with a no-tool procedure where you use a jumper wire and count some light blinks.
    There's a chance, though, that the only code that blinks on the ((!)) light will be the "hey, go read the codes for your master triangle" code.
  7. bisco
    51,155
    what does 'electric motor stopped' mean?
  8. 3PriusMike
    3,092
    2,413
    Silicon Valley
    Just a guess...it means the electric motor Is stopped :)
    Mike
  9. ChapmanF
    17,348
    Stopped rotating? Stopped applying power? Stopped supplying power? And if you ran a simple experiment on a bunch of Prius owners to see if they could tell you more often than chance when those things had happened (without relying on a scan tool), I wonder how many could....
    'Stopped rotating' would be the easiest to notice....
  10. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Which motor stopped? Actually, if either one stopped rotating, he couldn't have been driving the car at all.
  11. ChapmanF
    17,348
    That's what makes 'stopped rotating' easy to notice.
  12. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    Wow, my head hurts after reading all the posts.
