Electric motor whine when stopping
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joules, Sep 13, 2018.
  1. joules
    joules Junior Member
    Over the past few months I've noticed that sometimes when coming to a full stop I hear the whine of an electric motor. It happens just before coming to a full-stop, so at speeds less than 10mph.
    I'm guessing its related to the regenerative braking and its effect on the electric motor.
    The Prius has 230,000 miles so I'm not entirely surprised.
    But ... I'm interested in experiences and thoughts from other owners. Should I be looking at some particular repair or expect a major failure soon?
    DLC82SV likes this.
    52,362
    i have heard that on many hybrids since new. it is inverter whine, no worries.
    DLC82SV likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It's when you stop hearing it you should start to worry.....
    bisco and DLC82SV like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It's the sound of regenerative braking, which is done in loose terms by an electric motor running backwards. It sounds about the same when you accelerate by electric only. It's making the same sound at higher speeds, but is masked by louder noises.
    DLC82SV likes this.
  5. joules
    Thanks for the thoughts. They're about in-line with what I've been expecting.
    I've put 200k on the car and this noise is something new over the past few months. I expect its part of normal wear and tear. Thankfully there are no other catastrophic sounds coming from the car.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    No a mechanical whine is not normal.
    Have you ever replaced the trans fluid? Have you ever replaced the water pump belt?
