electric sailboat
Discussion in 'EV (Electric Vehicle) Discussion' started by hyo silver, Jun 11, 2010.
  1. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Yes, I know, this is a car forum. :)
    But, a sailboat's still a vehicle, and I know of a few sailors on PC, and there's certainly an interest in most things not petroleum around here, so...
    No, I'm not talking about doing away with the sails. But a boat still needs electricity, for lights and pumps at least. Refrigeration would be nice, too, and hot water, but such luxuries are typically beyond the capabilities of a small boat. Many have solar panels to help charge the batteries, but output is limited. Sometimes, a genset is used, and very few sailboats are without a small outboard. Despite the illusion of freedom, there's still a dependency on oil. Is it feasible for the prop to be used to power a generator, and charge the batteries, and power an electric motor when it's needed? Would there be enough electricity generated over the course of a windy day to run a desalinator and fill a hot water tank?
    Is a fossil-free sailboat possible? Like, one big enough to cruise the world and live on in something resembling comfort? :cool:
  2. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I'm a sailor. I would imagine the best approach would be a catamaran with solar panels covering the deck between two hulls. I think that could generate enough power for a small electric outboard motor and electronics.
  3. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    A catamaran would definitely give more area for solar panels. I see them as part of the solution, but not all of it. Around here, they'd only work about 3 months of the year. (But the hydroelectic is awesome) ;)
    What about a trailing water generator? The higher average speeds of a multihull would seem to make them more attractive than they would be on a monohull.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    How much information do you want? How much time do you have? ;)
    I have a small sailboat and it has lights, refrigeration, hot and cold pressure water, diesel fired hot water heat, diesel fired domestic hot water, shower, a gimbaled stove with oven, and a few other luxuries. You don't need a huge boat to get into a lot of systems.
    Addressing your questions:
    1) There are trailing generators which use the boat's motion to generate electricity. Generally these require too large of a propeller for meaningful amounts of power. They were okay for older cruising boats, where you only needed enough electricity to power the radios and maybe a light or two, but they aren't very practical for today's needs. Some of the new electric propulsion systems can be run in regeneration mode to make electricity. I don't have enough experience with them to tell you if they are practical in this respect.
    2) Solar panels and wind turbines are the two leading forms of green electrical generation on cruising boats. Which works better depends on where you sail. In the Great Lakes, solar panels work better since our average wind speed is low. In the Caribbean, wind turbines work well since the trade winds are generally steady. Wind turbines are larger and make noise, while solar panels require a lot of clear open space. Pick your poison.
    3) Most sailboat spend the bulk of their time in a marina or on shore. For these boats there is no need for wind turbines or solar panels. Shore power handles most of the need, while a bank of batteries work under way.
    4) We don't have solar panels or a wind turbine. I'm not against either, but the cost and space requirements make them not practical for my boat. Our approach is to be very thrifty with power use. We can typically go for over ten days on our house battery. Normally we have to run the engine long before that, so battery charging becomes a transparent part of moving the boat under power. The exception to this is when I do electronics development while at anchor at some remote island. Running computers, development equipment, the stereo and such puts a steady load on the battery. In these situations I may run the diesel strictly for power generation about every fourth day.
    Tom
  5. qbee42
    18,058
    3,074
    Northern Michigan
  6. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    As a daydreaming, wannabe engineer, both are pretty much limitless. :)
    Indeed. Part of the design problem, it seems to me, is fitting everything in a small package. Fitting everything into a folding, trailerable trimaran is even more of a challenge. Trying to do it all without the diesel...there's the rub.
  7. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    That sounds just about perfect, right up to the part about dinodiesel. Is there a place I can view more pictures of your boat Suzy?
    I like the style, but I'm not quite ready for intergalactic travel just yet. ;)
  8. qbee42
    18,058
    3,074
    Northern Michigan
  9. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
  10. hill
    8,158
    Most sail boats ... particularly small ones, use all the surface for 'people' ... whether tacking, furling/unfurling, sail packing/unpacking etc. Not very practical to be walking on your panels. But I was just thinking ... the paintable/flexable solar from JA Solar is in production as of this year (2010):
    JA Solar and Innovalight team up to commercialize 'silicon ink' solar cells -- Engadget
    I duno how they do it ... but the dang stuff is pretty efficient, too.
    http://www.jasolar.com/products_services_cells_mono.php
    I wonder how hard it'd be to sew these suckers onto the sail ... provided they, and the wirng wasn't too heavy.
  11. qbee42
    18,058
    3,074
    Northern Michigan
    PV panels are sometimes "glassed" into the deck so that they can be walked on. The two main problems with glassed in panels are: 1) You can't easily replace a failed panel, and 2) Heat dissipation. Not being able to shed heat reduces the effective capacity of the panels.
    Some sailors mount PV panels up in the air, either on davits or on some sort of pole. This gets around the deck space and cooling problem, but it means you have more top hamper and stuff to get in the way.
    Tom
  12. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
  13. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Hybrid boats are an interesting development. But one without sails isn't really taking advantage of available energy. Solar cells woven into the sails would be awesome.
  14. qbee42
    18,058
    3,074
    Northern Michigan
    Last year there was some information about a new hybrid/solar power boat that looked interesting. I can't find anything now, so perhaps it never made it past the prototype stage. It featured an easily driven catamaran hull with a large coach roof covering most of the boat. The coach roof was covered with PV panels that were supposed to provide enough power to drive the boat at 5 kts in full sun. Without sun you could run from batteries or a genset. Using the genset you could push the boat up to around 15 kts if you were in a hurry.
    Several things about this really appealed to me:
    1) For normal cruising you would never need to run the diesel genset.
    2) When at anchor, the big PV array is perfect for charging the house battery.
    3) When the sun isn't enough, you have a nice diesel genset.
    Tom
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Yes, that does sound attractive. So does all that sun. Sadly, it only works part time around these here parts, so hydroelectric shore power is far more reliable, not to mention considerably cheaper than all those fancy cells. Shore power would also do a great job of charging the onboard batteries. It's heading offshore without a diesel genset that would be the problem. I'm being too fussy, aren't I? :cool:
    I'll just have to find room for a couple of paddles somewhere. :)
    edit: Uh oh. The whole boat's made out of petrochemicals, isn't it?
  16. qbee42
    18,058
    3,074
    Northern Michigan
    Not my boat.
    Tom
  17. AkustaVirtaa
    198
    Finland EU
    That link what I did send, is about boat what can go electric 6 knots up to 25 nautical miles. Charging can made from solar panels or from diesel. Top speed with diesel is 15 knots.
    I think it is mostly fiberglass boat because it’s so low cost boat in that size.
    I agree that sails are much better choice for moving than diesel, I just like more motor boats because they are better in archipelago. We have much more shallow water here than you have. :)
  18. patsparks
    10,664
    567
    Adelaide South Australia
  19. hill
    8,158
  20. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Yes, pedal powered kayaks are awesome. Especially for a cyclist. :)
    But, they're kind small to live on, and the 'fuel tank' has a limited range. It'd make a good dinghy, strapped on deck for quick trips to shore. ;)
