Electric Vehicle Plans Through SC Edison
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by flim, Apr 2, 2012.
  1. flim
    flim Active Member
    254
    175
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    I recently received my Plug-In Electric Vehicle Rate Analysis from SCE based on my annual household usage and adding approx 2.5 hrs of charging 7 days a week.
    These are the total costs comparison with or without EV charging:
    1) Current annual household usage without EV charging on my current 5 Tier residential rate costs $1,073.13 (There are no On-Peak, Off-Peak or Super Off-Peak on this plan.)
    2) Current annual household usage with EV charging on a Two Meter Rate Option costs $1,273.15 (There are On-Peak, Off Peak and Super Off-Peak to plan your usage.)
    3) Current annual household usage with EV charging on Single Meter Rate Option costs $ 1,365.09 (There are On-Peak, Off Peak and Super Off-Peak to plan your usage.)
    4) Current annual household usage with EV charging on Current Residential Rate costs $ 1,501.91 (There are no On-Peak, Off-Peak or Super Off-Peak on this plan.)
    I just switched to the Home & Electric Vehicle Plan (TOU-D-TEV) - Single Meter and I will be saving $136.82 annually by replacing my current 5 Tier residential plan.
    The savings for a Two Meter Rate Option are much higher but the upfront costs for a separate meter, labor, etc are too expensive to justify this plan.
    I'm pretty sure I will be charging more than the 2.5 hrs I provided SCE for the analysis and my anticipated savings will be a lot more.
  2. samsdad
    samsdad Junior Member
    40
    Long Beach, CA
    Hi. I appreciate the breakdown, but can you explain more simply how much MORE money you think you'll pay per month, or per year, charging the Prius (I assume overnight, when the rates are cheapest)? I'm waiting on delivery of my plug-in this month, but when I called SCE I couldn't get a straight answer from them! They wanted me to change my plan, I think to the one you switched to, but the problem is we used the A/C way too much during the day -- live in Long Beach where it's pretty hot during the day. So, it didn't make any sense.
    I calculated, roughly, it would cost me about $1.25 to fully charge -- and this would only get me the initial 14 miles on all-electric. Doesn't seems to make good economic sense, when driving 14 miles on gas would, at $4.30 per gallon, and 50 MPG, costs me about he same!
    Is my math wrong? Thanks....
  3. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    If you are hitting the highest tier when you include the EV charging - then unfortunately yes, it's possible that gas is cheaper than electric. You may want to look into solar options to help get you down into the lower tiers.
  4. flim
    flim Active Member
    254
    175
    2023 Prius Prime
    XSE Premium
    There is no such thing as the cheapest time to charge in a Residential 5 Tier Plan because c/kWh are based on amount used and not time.
    These are my rates:
    Tier 1 13c/kWh up to baseline allocation
    Tier 2 16c/kWh from 101% to 130% of baseline
    Tier 3 24c/kWh from 131% to 200% of baseline
    Tier 4 27c/kWh from 201% to 300% of baseline
    Tier 5 31c/kWh more than 300% of baseline
    I will be paying $428.78 more to charge 2.5 hrs/day at my current residential 5 Tier Plan.
    With my new Single Meter Rate Option, I will be paying $291.96 or a savings of $136.82
    These are the Summer rates for the Home & Electric Vehicle Plan (TOU-D-TEV) - Single Meter
    Tier 1 Tier 2**=kWh usage greater than 130% of Baseline
    On Peak 20c/kWh 55c/kWh
    Off Peak 13c/kWh 25c/kWh
    Super
    Off Peak 10c/kWh 16c/kWh
    Peak Times
    On-Peak: 10am -6pm (weekdays)
    Off-Peak: All other hours
    Super Midnight - 6AM
    Off Peak
  5. pfile
    pfile Member
    319
    35
    bay area, ca
    did they analyze your smartmeter usage? i am on PG&E and do not have a smartmeter yet but i do have a TED5000. i collected a month's worth of statistics (minus my Leaf) and wrote a perl script to analyze the usage. i would absolutely get killed on any TOU plan - $100-$150 more per month.
    unless they have analyzed your daily usage and when you actually use power, i would be very skeptical about their analysis. that 55c/kwh will really kill you.
  6. samsdad
    40
    Long Beach, CA
    Thanks. You're right. I am looking at a solar option of charging a battery pack and then having that convert to A/C output. We'll see. Take care
  7. cheeseguy
    cheeseguy Junior Member
    38
    Yorba Linda
    I'm curious to find out if you discovered any solar options with the battery?
