Electrical contact question -- kitchen cooktop
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Sep 5, 2017.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,582
    Iowa
    My tale of woe is that somehow, the cooktop in my kitchen broke.
    I managed to get a local, family-owned dealer to take pity on my plight and offer me a new one for about $100 less than I could get it from any "big box store." Honestly, I would have ordered it from them if it were $150 more -- but would have caved if it were any more than that -- yes, I believe in supporting the local folk!!!!
    Anyway, they said they would install it for "free" -- but -- they could not make the electrical connection (something about stupid code laws).
    Since installing it is nothing more than dropping it in the "hole" on the counter, I declined. They did advise me that I need to use a special grease when I connected the wiring. Something about 99.9999 percent sure my supply line would be aluminium and the line from the cooktop is copper, which means they will corrode when connected.
    Hmmm. O.K., but he demurred on suggesting any particular solution, other than I needed a special electrical grease. My local hardware store was a bit clueless and the local electrical supply store went out of business several years ago after trying to compete with the internet and Home Depot.
    I ended up looking at NO-OX-ID "A-SPECIAL Electrical Grade" http://www.sanchem.com/electrical-contact-lubricant.html.
    Will this stuff work?
    Actually, I thought I had my husband all set to do this job, but he got irritated after I kept changing my mind about what sort of cooktop replacement I wanted. No matter, I find these types of jobs somewhat soothing, as long as there are no sparks or fire! :eek:
    RCO likes this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And I think it is 99.9999 % NOT likely that you have aluminum wiring in the house.
    Just LOOK at a bare wire end.
    Aluminum does not LOOK like copper.
    RCO likes this.
  3. cyberpriusII
    1,136
    1,582
    Iowa
    I actually did not look at the wiring from the panel to the cooktop -- yet -- as that involves taking apart most of the cabinet under the cooktop before taking apart the junction box.
    But, I did collect "cable remainders" the electrician left scattered around the house after he was here and installed the cooktop and several other items some several years ago. I figured I might use the leftover cable for something.
    The ones from the kitchen are aluminum. Black insulation, thick, aluminum cables. Well, O.K., bright shiny silver colored cable, they are. I assume it it not silver.
    #3 cyberpriusII, Sep 5, 2017
    RCO likes this.
  4. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    Installers made the move away from copper when the price started to enter the upper stratosphere. I am no electrical guru, and I am not familiar with the product mentioned, but you do need an antioxidant when you use aluminum. It creates a severe fire hazard, otherwise.
  5. Sam Spade
    2,036
    1,023
    2017 Prius c
    If that was less than 40 years ago, you need to find a new electrician.
    I don't think that any ethical one uses aluminum wire these days.
    I thought it had been banned nationwide a LONG time ago.
    Maybe not.
  6. bisco
    49,504
    any luck when googling the requirements? my results turn up anti oxidant grease. ideal is a big electrical manufacturer.
  7. bisco
    49,504
  8. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That is my understanding as well, that older houses may have aluminum wiring to the 220 volt receptacle and modern appliances have copper wires.
    I used an electrical grease like the one you linked to attach a new 220 volt receptacle onto the ends of my aluminum wiring to my range. So far, knock on wood, there has been no problem.
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Our house is about 25 years old, and definitely has aluminum wiring to the 220 volt original range location.
  10. ChapmanF
    15,653
    During the time EC alloy aluminum wire was in use, millions of houses were built with it. No-Ox-Id is good stuff but not sufficient (oxidation is only one of the ways aluminum wire terminations fail). The main requirements come from this section of the National Electrical Code:
    Breaking that down a bit: (1) you can't connect the aluminum wire directly to the terminals of your cooktop, unless those terminals are clearly identified as suitable for aluminum. Historically, two different designations have been used. Back in the '60s/early '70s, there were devices marked AL-CU that were believed to be suitable at the time, but a lot of fires proved that belief wrong. The new designation introduced after that was CO/ALR, and that's what you need to look for on any device that you're going to hook to your aluminum wiring.
    (2) If the cooktop doesn't have CO/ALR terminals, you can use short pigtails of copper wire (of the appropriate gauge), connect those to the cooktop terminals, and splice them to the aluminum wire, using splice connectors listed for that specific use. There has to be room in the junction box for the extra wiring and connectors. Other sections in the code specify "maximum box fill", or how many wires and connections, of what gauges, are allowed in a box of a certain cubic-inch volume. It's not just "how many can I fold and pack in there" because heat has to be taken into account, so possibly you'd end up retrofitting a larger box into the wall.
    (3) You can also see, in the code excerpt above, that the splicing connector between copper and aluminum isn't allowed to let the two metals touch. It has to be of a design that clamps them both, but separately. Generally like this thing. There appears to be one exception, though: according to the 2008 NEC Handbook (p. 47), "On February 2, 1995, Underwriters Laboratories announced the listing of a twist-on wire connector suitable for use with aluminum-to-copper conductors ... (t)hat was the first listing of a twist-on type connector for aluminum-to-copper conductors since 1987." The Handbook doesn't plug it by name, but it's apparently the #65 from Ideal, a twisty wire nut that's color coded purple and supposedly ok for the job, but if you google it even slightly, its reputation is not good. Another technique is a special crimp connection, "COPALUM", that keeps the two conductors separate, and is crimped by a special crimp tool, wielded by a COPALUM-certified electrician.
    So for DIY, probably the Alumiconns listed above are easiest. From what I read, they come pre-dabbed with an antioxidant gel, so you don't even need a separate tube of No-Ox-Id. You should make sure you have an inch-pound torque driver (which you may have already for hacking on your Prius), to make sure you can follow the connector's torque specifications closely. Every detail of connecting aluminum to copper is serious.
    Speaking of Prii, Toyota also uses aluminum in some of their wiring. They generally also color-code the aluminum wires purple, and they also have special crimp connections and heat shrink covers, with their own matching crimp tool, and painstakingly specific instructions for doing any splicing on the stuff.
    -Chap
    Here's a longish but fascinating historical article on aluminum, and later copper-clad aluminum, in branch circuit wiring.
    #10 ChapmanF, Sep 6, 2017
    Andyprius1, bwilson4web, RCO and 2 others like this.
  11. Elektroingenieur
    2,515
    3,259
    Three Touring
    The Toyota Wire Crimper SST (09042-2C100), from photos in service bulletins calling for its use (PDF), is just a Lobtex AK15A with a high markup (list price ¥10,100 or $130.25). I bought one for $40 or so from Mutsuura Honten Co., Ltd. (established 1892) on Rakuten; it’s a high-quality (made in Japan, JIS mark), controlled-cycle tool for hand crimping of non-insulated splices.
    Andyprius1 and jerrymildred like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Nice, @ChapmanF!
    I don't blame the installer for shying away, but you'd think they would have checked to see if the wires actually were aluminum. But it looks like you've confirmed that. In that case, I agree with Chap. In fact, I'd suggest a licensed electrician do that job for you. They have special crimpers like this for aluminum to copper connections.
    Or else you can use something like what Chap suggested, but will need to use some sort of torque driver for the screws.
    By the way, I know you must be frustrated, but those codes are there for really good reasons. I only wish they had never permitted aluminum wire to begin with.
    Andyprius1 likes this.
  13. Trollbait
    11,563
    Take a file, emery cloth, or even a blade to it. Copper wire can be coated with a silvery metal(tin?).
    If it is aluminum, I found this site informative.
    Aluminum to Copper electrical connectors
    If the outlet isn't CO/ALR, replace it. Corrosion on aluminum overheating is only part of the issue. The other is that aluminum expands more than copper as it heats. This causes the connections on an unapproved receptacle and switches to loosen overtime.
    Noting where you live, I'm guessing it was cheaper than copper. For the mainland US, the '60s and '70s was the period aluminum was mostly used in new homes.
    jerrymildred and xliderider like this.
  14. jerrymildred
    11,511
    14,113
    Tampa, FL
    Thanks. I forgot to mention that.
    Another tip. I always go back after I get done terminating copper wires and usually get another quarter turn or more on the terminal screw, especially with solid strand wire. It seems that the copper must relax a little or something.
    RCO and bisco like this.
  15. cyberpriusII
    1,136
    1,582
    Iowa
    I assume, since the appliance store people insisted that pretty much all the homes in region have the aluminum/copper connection -- that it is the common process here.
    Also the electrician I used is one of the more respected ones in the region and is actually still a young guy -- early 30s, anyway.
    I also assume that when I replace the cooktop I just unhook the connection he did seven years ago -- and using the same connectors -- with some special anti-oxidant -- just connect the new cooktop wire to the existing cable with the existing connectors.
    jerrymildred likes this.
  16. ChapmanF
    15,653
    I suppose you'll know more once you duck under there and look. If you find copper cooktop wires running down to aluminum branch wires and connected using some things, you can snap some closeups of the things, and see what kind were used.
    I can think of a few possibilities... if you find things that are separate-screw-clamp deals like the AlumiConn connectors shown above, and they're in purple insulation with clear manufacturer's marks and approved for the use, they'll be reusable. Grab your inch-pound torque driver.
    If they turn out to something like the Copalum crimp connectors, you can't reuse those, they're crimped. You could cut them out and have them redone (takes an electrician certified to use the power Copalum crimper), or just cut them out and replace them with AlumiConns. Or maybe it would be easier to just cut the old copper and splice to that, which needs no special precautions. Maybe the existing copper pigtail is long enough to reach all the way to your new cooktop terminals ... problem solved.
    A grayer area is if you find whatever was used 7 years ago to join the al to the copper, take your closeups of it, and it doesn't turn out to quite be anything approved for the use. That never happens, of course (cough). In that case, you'd have a good opportunity to re-do it with something that is.
    -Chap
    Andyprius1, RCO and jerrymildred like this.
  17. Trollbait
    11,563
    If its AlumiConn or Copalum, I'd just cut the old cooktop wires and connect to them. No need for grease or anything else.
  18. bwilson4web
    15,524
    Just a 'shade tree' approach, I left the cover off the junction box and tested the connections using an IR thermometer to measure the heat with the stove top at max power. Not seeing a temperature rise after 10 minutes, I turned everything off and put the cover on ... about 15 years ago.
    Andyprius1, RCO and bisco like this.
  19. ChapmanF
    15,653
    Did you also have aluminum-to-copper splices going on there, or were you just looking for a reason to use an IR thermometer?
    The sneaky thing about Al/Cu junctions is if everything isn't Just Right, they don't necessarily stay the way they were 15 years ago.
    -Chap
  20. bwilson4web
    15,524
    No and yes.
    I used the same technology that the original range wiring used, wire nuts, only new ones.
    Agreed but heat is a good indicator if something is going wrong.
    Andyprius1 and RCO like this.
