electronic key not unlocking doors or allowing car to start
Discussion in 'Knowledge Base Articles Discussion' started by rcard0, Aug 4, 2011.
  1. rcard0
    rcard0 Junior Member
    23
    PNW
    2006 Prius w/ "the works"
    34,9k miles
    I replaced the batteries in our FoBs a couple of months ago, so I was sure they were ok. Tested them anyway, they are @95%.
    So, both FoBs do not unlock they doors when you approach and grab door handle, and will not allow starting the car w/o inserting them into the key slot.
    I still have 6 mo's on warranty, so unless someone knows a trick to fix this I guess a trip to the dealer is on the schedule. :mad:
    Thks!
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Could be the 12-volt battery in the trunk, just replaced mine
  3. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Did you check that the SKS button under the steering wheel isn't disabling the Smart Key System?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This is most likely the problem.
    Tom
