ELM-327 with windows laptop
Discussion in 'Gen 3 Prius Main Forum' started by richk, Jun 25, 2015.
  1. richk
    richk Junior Member
    San Francisco
    Can anyone recommend one of the ELM-327 interface modules (many available from $10 to $20 from Amazon) for use with a windows laptop? The ones I have seen that come with PC software talk about needing XP or some sort of 32 bit win7. I would prefer one that connected via Bluetooth, but USB might be acceptable. I need it to run on a windows 8.1 64-bit machine
    49,481
    will the mini vci work?
  3. richk
    richk Junior Member
    San Francisco
    It is for a new Prius (2015) and I assume it will work but I'm not sure.
    49,481
    it should, i think windows 7 is minimum.
  5. richk
    richk Junior Member
    San Francisco
    Thank you. Will I need any additional software to read diagnostic info or make simple changes like turning off the reverse beep?
    Everything I have read indicates this runs on 32-bit OS only.
    #5 richk, Jun 25, 2015
