emergency braking alert????
Discussion in 'Prime Main Forum (2017-2022)' started by nbecker, Jan 19, 2018.
  1. nbecker
    nbecker Junior Member
    Driving to work in my prime premium, turned off the highway onto the ramp to merge onto the secondary road. I'm looking left to merge into the traffic, then when I look back ahead of me, I see the idiot in front of me had STOPPED DEAD IN THE ROAD. I'm going about 50+ mph, about 100-200ft behind him/her. Applying full braking, I luckily managed to steer around and luckily nothing was there in the road to my left.
    I doubt I could have safely stopped without hitting him/her.
    So this whole time, the emergency braking /alert did absolutely nothing. What's the deal?
    52,373
    was it on?
  3. nbecker
    I didn't know I could turn it off. How can I tell?
  4. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    if you have you're foot hard on the accelerator it won't engage.. it assumes you're in the process of taking evasive maneuvers so it won't cut power and potentially put you in a bad spot. likewise if you turn hard, etc. it also won't engage.
    that's a catch 22... you're accelerating hard to merge and an idiot stops. that's the main dead zone in the system operation.
  5. nbecker
    I think I was just coasting while looking to the left, and I think I should have expected an alert
  6. bisco
    52,373
    idk if it can be turned on/off, just a thought.
  7. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    What color was the car you would have hit?
  8. MikailSJ
    MikailSJ Member
    35
    27
    I don't think the alert goes off 100-200 ft out.
  9. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    In the UK it only works below 30 or 40 mph. It isn’t all speed. If cruise was engaged then that might have braked.
    iPhone ?
  10. ct89
    ct89 Active Member
    323
    266
    New England
    On my highlander (and I'm sure I've seen the same on the prime) even if you are accelerating, the display will flash a bright BRAKE.
    It doesn't take any action but it still flashes and beeps. It's pretty easy to activate. If you are speeding-up to pass someone in front of you and are late (according to it and my wife) fully moving over to the left lane, bingo...You get scolded...
    Check the owners manual...
    Page 369 starts a whole description of how to enable/disable and when the system might not activate.
    For almost all the cases, even if it doesn't activate, it should flash the BRAKE warning.
  11. fuzzy1
    10,602
    At 50 mph, it should be able stop in 90-ish feet, unless the tires are worn or the road conditions are compromised precipitation.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I wish people would RTFM.
    Page 373.
  13. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    If people would RTFM, that would eliminate 1\2 of the topics. If we then removed all of the Facebook-type posts, we would have a manageable and informative database. Why would we want to do that?
    ct89 and Tideland Prius like this.
  14. bisco
    52,373
  15. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Reading the manual is like asking for directions. Ain't gonna happen.
    sonomac likes this.
  16. geguia
    geguia Active Member
    210
    108
    los angeles
    you must be fun at parties.
  17. Lee Jay
    5,850
    4,036
    No one is fun at parties.
