Emergency Flasher during Car Start up
Discussion in 'Prius c Technical Discussion' started by Linqhao, Nov 25, 2015.
Tags:
  1. Linqhao
    Linqhao Junior Member
    Kuala Lumpur
    Did any one experienced the emergency flasher flash once or twice, when starting up the car (press brake + push start button)? What does these mean to my car? An error indicator? I've been facing this sometime but not too frequent, Toyota service guy said no error code appear in OBD?
    49,691
    welcome! what is the 'emergency flasher'? do you mean both turn signals at the same time?
  3. Linqhao
    Kuala Lumpur
    Yes! both turn signal light flash one or twice~
    49,691
    i've never seen it, but i don't have a c. if you're not getting a code though, it's probably nothing to worry about.
  5. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Do you keep the headlight switch in the ON position, even when the car is shutdown?
  6. Linqhao
    Kuala Lumpur
    No, I will switch off the headlamp everytime due to the reminder sound! But if our 12V battery in low charge state will cause the flasher blink twice to notify us? Sometime when i turn off my car after a ride, the flasher will also flash 1 time.
  7. xliderider
    7,891
    3,125
    Honolulu, HI
    It almost seems like the same flashing behavior when the car lock/unlock actions are triggered by the key fob.
    How old is the battery in your fob? If it's 2 or more years old, I'd replace it.
  8. Calum G
    Calum G New Member
    Grand junction
    2015 Prius c
    I have had this happen to me once. I got in the car and turned the key and had my flashers flash twice. Don't think the actual blinkers came on but it showed up on the dash.
    2015 Toyota Prius c with 1700 miles.
  9. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I agree with xliderider, I'd replace the battery in the fob then check it.
  10. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    My C three lit the triangle and said KEYFOB BATTERY IS LOW in the dash upon turning the car off just today. Hazards did not come on.
  11. nagrath
    nagrath Member
    139
    43
    Putnam County, New York
    2023 Prius Prime
    XSE
    This happened in my 2013 Gen 3 Prius the other day, I don't know why. Fob battery is only a year old, but fob is 8 years old.
