Empty tank, but can only fill 1/2 the way
Discussion in 'Gen 2 Prius Main Forum' started by gqscientist, Mar 19, 2006.
  1. gqscientist
    gqscientist New Member
    36
    Manhattan Beach, CA
    I have noticed more than once when filling up my empty tank the pump shuts off (auto full stop) 1/2 to 3/4 of my tank being full. I have never had this happen with any other car. Does this have to do with the bladder system?
  2. daniel
    14,487
    1,518
    Spokane, WA
    It's the fuel fill pipe. It's tight. Different gas stations (or different pumps at the same station) may be set to different sensitivity for the vaccuum-operated shut-off. Try another gas station. If it happens consistently take it to the dealer. In some early 2004's it was enough of an issue to have a TSB, and people who complained got a free replacement. Later units already had the improved fill pipe, but people still occasionally report this problem
  3. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
  4. aaf709
    3,862
    2022 Prius Prime
    I've had some success with not using the auto-shutoff and filling slowly.
  5. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    Or if using auto pump - then only use the first click on the handle (the slowest speed).
  6. storm petrol
    storm petrol Member
    106
    17
    44 degrees, 42 minutes North; 73 degrees, 29 minu
    That will do it.
    I find myself going to an aging gas station with older, slower pumps.
    storm petrol
