Enable auto speed door lock
Discussion in 'Prius c Technical Discussion' started by Ishantha, Mar 25, 2015.
  1. Ishantha
    Ishantha Junior Member
    Sri Lanka
    2013 Aqua
    hi guys, anybody know how to enable auto door locking in prius C - 2013 when the speed exceeds 12 mph(20 km/h) ?
    tried the user manual settings in page 68-69 but no luck :(
    power switch to β€œON” mode, shift the gear to β€œN” and press door lock button.
    please share if anyone success thanks.
  2. thetakara
    thetakara Junior Member
    36
    That should be within the setup button.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Have someone else read the manual and try to do it.
    Sometimes the manual is not clear and sometimes you think ahead too far.
    I've done that on two different things now; it's embarrassing.
  4. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    Yes I also tried it same procedure, but no luck,, nothing happened.
  5. bisco
    49,490
    might need tech stream.
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Carista might work, but Techstream is the safe bet.
