Enabling My Room Mode on Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Gerberknight, Aug 30, 2021.
  1. Gerberknight
    Gerberknight Junior Member
    Los Angles
    I'm wondering if there is a mod or hack one could do to enable My Room Mode on the prius prime, so that it will function similar to the RAV4 Prime?
    Thanks!
  2. Washingtonian
    Washingtonian Senior Member
    726
    621
    I have never heard of "My Room Mode". Could someone tell us what it is or why it would be something I would want in my PP?
    PtPri and Mendel Leisk like this.
    52,393
    does it convert your prime to a den, study, library? bedroom?
    privilege and Raytheeagle like this.
    52,393
    even google is not clear
  5. bisco
    52,393
    okay, i had to waste 2 1/2 minutes of my life watching a very poorly done video, for 5 seconds saying you can use the vehicle accessories while plugged in so you don't have to deplete the battery and run the engine.
    no, i have not read of anyone hacking their prime to do this.
  6. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    As I understand it from very little reading, while at a public charger you sit in the car with climate control running and wait in "My Room" for the charge to complete.
    privilege and Gerberknight like this.
  7. Gerberknight
    Los Angles
    Hey bisco,
    It's when you can have your Rav4 Prime on while charging at a station. That includes the Air Conditioning. The reason you would want this is if you were charging in the middle of no where and it's hot or cold outside, you would be able to stay in your car and just have the AC running while it's charging.
    Another reason is if you prius camp, you could charge the prius and have the Climate Control running while you sleep at night.
  8. Gerberknight
    Los Angles
  9. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Hoping it isn't a bathroom:eek:.
    JoeBlack and bisco like this.
  10. bisco
    52,393
    it's a nice feature, and many have been surprised over the years that prime doesn't have it. toyota is probably using it as a perk for the much higher priced rav
  11. Trollbait
    12,687
    May not have occurred to Toyota to have it for the Prius Prime. It came out years before the Rav4 Prime, and has CHAdeMO standard in Japan.
  12. Primefan
    Primefan Junior Member
    42
    Virginia
    @Gerberknight it is a common annoyance of the Prime that it wants to shut down the AC while charging. I’ve collected anecdotes I have yet to try (at the moment I don’t charge my prime except in charge mode while driving).
    This link should take you to one set of directions. Please let us know if it works while charging:
    Can I use A/C when charging? | PriusChat
    When not charging you can stay in the car, locked from the interior, and the AC will run nicely as long as you have gas. However the motor will repeatedly turn on to recharge the system. The motor turning on and off is less than ideal for those in the vehicle, and any others around them, when trying to sleep. The rate of discharge of the battery, leading to the motor running, is, of course, dependent on the load the AC puts on the battery.
    I’ve seen someone recommend another option for camping but it seems like it has a number of potential problems. Others can comment. I plan to try it but haven’t yet.
    If the Prime is fully charged (or 80% using charge mode) one has a lot of reserve battery. If the Prime is left in neutral, with the parking brake on, it is my understanding that energy will continue to flow from the traction battery to keep the AC running without the engine ever starting. Critically one would need to carefully monitor the traction battery so that it does not fully discharge and the vehicle is left unable to start (same would be true for the RAV4 if room mode means the engine doesn’t start). Obviously you’ve got another big problem if a camper knocks the shifter out of neutral. There may be other dangers I’m unaware of.
  13. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    The only way to do this in a PP is to sit in it while charging ( with doors locked ) and hit the AC button on the remote every 10 minutes. You wil not be able to listen to the multimedia like the real '' my room '' mode of the RAV4 Prime. But at least you will get AC while charging.
    Gerberknight likes this.
  14. privilege
    privilege Active Member
    659
    169
    Birmingham
    oh wow, I never considered this being an issue while charging.
    I mean, who, in the planning and engineering committees, said " let's turn off all the comfort/accessories while it's charging" ?
    and why didn't anyone in the room say "get Charlie, I know you're the head of the charging committee, but let's think this one through ... if I'm at a charging station and it's hot/rainy, shouldn't I be able to run the defrost , radio, wipers, etc ?"
    imagine someone used to watching a movie in their Tesla while charging, getting into a prime and saying "what the heck????"
  15. Mendel Leisk
    41,906
    What about anti-idling laws, or is that not a thing anymore? I really bristle, walking through mall parking lots, past idling/parked cars, mostly with single occupant, AC running, car pumping out heat, and tapping away on their phones. :mad:
    Appreciate I’ve got a “tough audience” here… :whistle:
    PtPri and lbligh like this.
  16. Trollbait
    12,687
    Most of the signage I've noticed for anti-idling refers to diesels or over 5 tons(commercial trucks).
    I've stopped going to restaurants that are drive through only now.
  17. Mendel Leisk
    41,906
    Yeah when we sit outside at nearby starbucks with our doge, there's a slow-motion parade: the drive-thru participants, mostly in trucks and CUV's, slowly inching forward, heads-down, basking in the cellphone glow.
    One time sitting there, I started expounding to the missus, I should attend a Coquitlam open-to-public counsel meeting, propose the name of the city be changed to Drivethruville. Might help to wear a pied jester's outfit...
    jerrymildred likes this.
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    For PP, I would skip charging on the road if you have to stay inside of the car for the duration of charging ~2 hours minimum. It only gains 25 miles of EV range, and unless it is free, most likely it would cost more than buying gas. If you are parked and need to remain in the car to rest or sleep, the best bet would be to just keep the car in READY and lock the door from inside*. You can keep the AC on as long as you have gas. The engine will come on as needed.
    *Locking the door from the inside is necessary for the 2021 and newer PP models in order to keep the hybrid system in READY mode for longer than ~1 hour while in PARK. This may not apply in pre-2020 PP.
    lbligh likes this.
  19. Ovation
    Ovation Active Member
    156
    130
    Quebec
    Would a full battery in this mode last 2-3 hours without gas engine coming on with moderate A/C? Just curious for drive-in movie purposes.
  20. Salamander_King
    11,024
    8,970
    New England
    It all depends on how hot or how cold the ambient temps are and your A/C setting. But generally speaking, with moderate setting the full battery charge should last 2-3 hours without gas coming on. I think I read on another thread some had A/C on all night without the engine coming on.
    Ovation likes this.
