Energy Capacity of the Hybrid Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by max2prius, Jan 26, 2008.
  1. max2prius
    max2prius Junior Member
    85
    Walnut Creek, CA
    I have always wondered, does anyone know what the hybrid battery capacity is in Kilowatt hours? I have tried to do a search but it only states in amp hours which I have no idea to convert to KWH.
    I have owned my first Prius since Dec 1, 2007 and am loving it.
    Thanks
  2. haiku88
    haiku88 New Member
    Sonoma, CA
    (amphours x volts)/1000 = kwh
  3. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    It seems to me that I've heard it is 1.2 or 1.3 KWH.
  4. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As stated above the capacity is 6.5watt-hours*200volts = 1.3 kwatt-hours. Only about 1/2 of that is actually available for use to protect the battery from early failure. The capacity will slowly degrade over the life of the car so mine may be down to as low as 50% of its original capacity at this time (4 years and 107,000 miles.
    My Prius still gets the same great MPG now as it did when new so the battery is still doing the job.
    JeffD
    PriusCamper likes this.
  5. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    A small correction, 6.5Ah * ~200V = ~1.3kWh. In general for DC systems, Volts * Amps = Watts, and similarly Volts * Amp hours = Watt hours. AC can be trickier.
    You can find more info on the Prius battery here:
    Toyota Prius Battery Specs - EAA-PHEV
    Rob
    Morfeas likes this.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    You only get 600Wh of that to play with, though, due to the SOC
    limits. Which allows you to suck up about 600 vertical feet
    of drop, coincidentally. Here [in the second part] are some
    experiments and commentary that you might find amusing.
    _H*
  7. Qlara
    Qlara New Member
    488
    From Toyota's Prius spec:
    Traction Battery
    Battery Type
    Sealed Nickel-Metal Hydride (Ni-MH)
    Battery Power Output
    28 hp (21 kW)
    Battery Voltage
    201.6V
    Capacity
    6.5Ah or 1.31kWh
  8. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    OP asked for energy capacity, not power output.
    Power = energy/time, or energy = power * time
    The power rating of battery tells you how fast it can deliver the energy contained in it, but tells you nothing about the total energy stored in the battery. Energy density and power density of a battery are two different properties of a given battery technology, but both are important in automobile powertrain applications. In greatly simplified terms, they dictate how far you can go and how fast you can go. Two different things.
    That ends today's 8th grade physics lesson.
    KhaPhoRa likes this.
  9. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So, if you extracted all of the effective HV battery capacity of 1.31kWh at the maximum power output of 21kW, it would maintain that power level for 1.31/21 x 60 = 3.74 minutes. That assumes the quoted 1.31kWh capacity is the effective allowed capacity between the upper and lower charge limits.
    Not a lot of time, eh! Which is why you need that ICE sucking, squeezing, banging and blowing that hi-energy fossil fuel in parallel. There's a lot more energy in that stuff, which is just as well; most of it gets lost before it gets to the road-wheels.
  10. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    The battery is kept between 40 and 80% of its capacity. Because of this, my understanding was that the capacity is barely affected over time... If your battery only had 50% of its original capacity, wouldn't it show in your mileage? (especially in city driving where regenerative braking is so important)
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes it might impact a bit on the mileage but I've seen tests that have shown up to 50% loss of battery capacity gives surprisingly little MPG loss under normal driving conditions. The reason is that the vast majority of the time (in normal driving situations) you're not using all of the available SOC (state of charge) swing anyway. For example the nominal SOC is somewhere around 60% and you'll find that most of the time it's staying within +/- 10% of this value. As the battery capacity declines the SOC swings will typically increase, so a 60% to 70% swing for a new battery might result in say a 60% to 80% SOC swing for a battery that was nearly worn out.
    Anyway, what I'm trying to say is that it's because fairly small SOC swings (typically < +/- 10%) are very common whereas large SOC swings that use close to the full available SOC swing (40% to 80%) are relatively rare. If the battery lost 50% capacity then sure those occasional large SOC swings would not be possible, but the more common smaller SOC swings would be unaffected.
    TheDoof likes this.
  12. spidgorny
    spidgorny New Member
    Frankfurt am Main
    So it's 6.5Ah which is equal to 1.31kWh. How does it compare to
    - Tea Kettle 2000W
    - Smartphone battery 2000mAh?
    My guess:
    2000mAh = 2Ah. So Prius battery has merely 3 times the capacity of smartphone battery ?!?! Why is it so big then?
    2000W*1h = 2kWh. So Prius battery is not enough to hold an hour long tea party with a boiling kettle all the time?
    General logic says the Prius battery must be quite powerful. I must be wrong somewhere.
  13. pjc
    pjc Member
    139
    46
    Bloomington, MN
    spidgorny,
    On the first count, you are wrong in the respect that the important figure of merit is energy capacity (Watt-hours), not charge capacity (Coulombs = Amp-seconds = Ah*3600). You get Wh from Ah by multiplying by the voltage. A cell-phone battery is only a few volts -- mine is rated at 3.7V and they converted it for me to 4.44 Wh. That's compared to the 1300 Wh of the Prius battery which is at a nominal 200V. Also, your smart phone is Li-ion, which can hold a higher energy density than the NiMH Prius battery.
    On the second count you are correct. A 2000W tea kettle running for an hour will indeed suck down 2 kWh of energy. That's the same amount of energy you need to move your whole Prius about 10 miles down the road on pure EV (if you figure 200 Wh/mile for a Gen2). That's why you don't see many battery-powered tea kettles! ;)
    KhaPhoRa and spidgorny like this.
  14. Tinkerer @ Gajetest
    Tinkerer @ Gajetest New Member
    Placerville California
    Well The formula is simple as was stated already The formula is fairly straight-forward.
    kilowatthours = (amphours * voltage) / 1000
    C Wagner likes this.
  15. bisco
    51,952
    thanks, i've been waiting 3 years for that!(y)
    C Wagner, PriusCamper and m.wynn like this.
  16. Triparadox
    Triparadox Active Member
    201
    108
    You don't divide by 1000. Just multiply the Amps with Volt since P (Energy) = I (Amps) * V (Volt)
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's not the question, though. The original question from 11 years ago was converting amp/hours to kWh. They had no idea what the amps were. If you already know the voltage and the amp-hours, there's no reason to do any other math. Just multiply them and move the decimal point.
  18. ChapmanF
    18,216
    Tinkerer had it right: the original poster wanted energy, which has units of power and time, where you can get power by multiplying voltage and current. The answer needs to be a product of voltage, current, and time.
    Tinkerer got there by multiplying amphours (supplying the current and time) and volts (supplying the voltage). That would give watthours, which is a perfectly good energy unit in its own right, but the OP was asking for kilowatthours, hence the division by 1000.
    "don't divide by 1000. Just multiply the Amps with Volt" misses two parts of the problem: it comes out only in power, not energy (power · time), and it leaves out the factor of 1000 in the kilo prefix.
  19. Triparadox
    201
    108
    Yeah I forgot to add *time (in hour). And if the case is to find KWh, then yeah.. divide them by 1000..
  20. GreenApp
    GreenApp Junior Member
    43
    IF you're still getting the same great mileage, your battery is not as degraded as you may think.
