energy flow when car when car is not moving and brake pedal is pressed
Discussion in 'Gen 3 Prius Main Forum' started by GUILLEN, May 25, 2018.
  1. GUILLEN
    GUILLEN New Member
    CALIFORNIA
    hi everyone has anyone had this problem i can't find a similar problem on the internet.when the Prius is on a complete stop with the brake pedal pressed i can see on the energy monitor display energy flowing to the electric motor and i can hear the electric motor working i check the brake pedal switch and brake pedal position sensor and they look like they are ok .i really appreciate any help
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I think there is nothing wrong. When stationary with the brake pressed, there is power applied to the MG1. You can notice this because there is a slight movement when you go from P to D and when you release the brake pedal the car immediately wants to creep forward.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    I see that if I'm not pressing down enough on the brakes. Car is still so it's enough brake pressure just not enough to stop the current. Would think there's some adjustment or setting. I have a gen 2.
  4. GUILLEN
    GUILLEN New Member
    CALIFORNIA
    hi thanks for the reply it's not normal to see energy flow to the motor when the car is in a complete stop and the brake pedal is pressed.i will record a video tomorrow to show the problem and will be getting a new brake switch to try it
  5. bisco
    51,886
    if the switch was not working, you wouldn't be able to make the car ready. do the brake lights operate?
  6. GUILLEN
    GUILLEN New Member
    CALIFORNIA
    yes brake lights operate.i was busy today and didn't had a chance to replace the brake switch
  7. GUILLEN
    GUILLEN New Member
    CALIFORNIA
    Here is a YouTube link to a video that I recorded
  8. audiodave
    800
    272
    US
    That's with firm pressure to the peddle?
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    That does not look normal at all. And as @bisco said, if the brake switch failed to work you couldn't make the car READY.
    GUILLEN likes this.
  10. RRxing
    RRxing Senior Member
    2,546
    1,821
    NEPA
    Your ABS and Slip Indicator lights are illuminated, which are issues that could relate to your problem. The Slip Indicator could just be because you mashed the brake pedal down when you stopped, but the ABS light indicates another problem. Get them checked out. Also, get that windshield replaced!
  11. bisco
    51,886
    good catch!
    GUILLEN and jerrymildred like this.
  12. jerrymildred
    11,517
    14,149
    Tampa, FL
    Yeah. Good catch indeed, @RRxing. I was so focused on the energy flow, I missed everything else.
    GUILLEN likes this.
  13. GUILLEN
    GUILLEN New Member
    CALIFORNIA
    Thanks for all the info I just got this nice car las t week :) and like RRxing said it was a ABS problem.it was the right front wheel speed sensor wire it was completely cut I solder the wires together and cleared the ABS codes and now I got rid of all the warning lights and my anergy flow is now normal.thanks for all the support
    RRxing and jerrymildred like this.
  14. RRxing
    2,546
    1,821
    NEPA
    Also, your Brake light is on, which should only display if the parking brake is on. Was your parking brake on when you filmed the video? If not, it's another clue that something ain't right.
    And get that windshield fixed... :whistle:
  15. Kuluz4Dayz
    Kuluz4Dayz Junior Member
    Hawai‘i
    Four Touring
    I’m having this same issue with my 2016 but it only has energy flowing while I’m stopped on a hill. Not sure why it’s doing it as it’s not normal and no fault codes were found.
