Engine Air Filter
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Sep 21, 2014.
  1. markabele
    5,084
    1,782
    Nebraska
    I assume it is the same filter on the PiP as it is in all other regular Gen3 models (excluding c and v)?
    And is it as easy to change/DIY as most other car air filters are?
    Thanks!
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Yes it is
  3. mrbigh
    3,686
    699
    Long Island, NY
    same filter
    51,140
    i'm glad you brought this up. at 20,000 miles, 6,700 hv, i'm curious to see what mine looks like. cabin filter as well.
  5. ETC(SS)
    6,952
    Same motor....same filter.
    Yes. it's easy to change.
  6. Mendel Leisk
    40,574
    I'm thinking a PIP engine filter is gonna last a long time.
  7. bisco
    51,140
    mine is like brand new. two clips on the front of the housing and hinged in the back. but the duct connection makes it difficult to lift without disconnecting. i was able to pry it up just high enough to lift and slide the filter out toward the front.
  8. Mendel Leisk
    40,574
    Yeah, it's best to just jiggle the lid off of those two hinge/hooks at the back (if you didn't), then it's much easier to reach and remove the filter.
  9. GregP507
    GregP507 Senior Member
    3,002
    481
    I don't get excited about changing an air filter unless it's very dirty or I can see holes in it. Not since the days of carburetors, has a dirty air filter caused reduced fuel economy.
    Reduced airflow only reduces my fuel consumption -I'll take it.
  10. bisco
    51,140
    checked the cabin filter, forgot what a pain the glovebox is. it was fairly gray with a few tree bits. i'll pick up a new one and replace it. should have had one at the ready, so i wouldn't have to repeat the surgery. the functioning of the glovebox seems to get a little worse every time you have to remove it. interesting that the o/m doesn't have either filter in the diy maintenance, and the cabin filter said 'bring to toyota dealer'.
  11. bisco
    51,140
    while i was under the hood, i checked my battery voltage in the fuse box. 12.6v after 29 months and two winters of sitting for 5 weeks uncharged. can't complain.
  12. bisco
    51,140
    thanks, i should have asked first. typical male.:cool:
  13. Mendel Leisk
    40,574
    By "much easier" I meant it's then humanly possible. I'm halfway convinced that automotive engineers get together behind closed doors, and specifically plot ways to make access, fastener/clip design etc, as close to impossible as possible.
  14. bisco
    51,140
    agreed. it's funny, the front clips pop right off. you see the hinges and think, great design! i think the gen II was easier?
  15. markabele
    5,084
    1,782
    Nebraska
    Anyone have links they would recommend for engine air filters and/or cabin air filters? (whether either on the shop on this website, or Amazon)
  16. GregP507
    3,002
    481
    It must be a well-built battery. But some battery manufacturers don't mind if the battery slowly discharges itself internally. That way, they can sell you a new one, when it won't take a charge, and you can be blamed for it's destruction.
    I'm old enough to remember when some places were still not connected to the grid, and they used lead-acid batteries in glass-jar enclosures, charged by a windmill or a donkey engine. Those batteries sometimes went completely dead, but no one was too worried; they gave them a heavy charge to desulfinate the plates, and they were good-as-new. Some of those batteries were still being used after 50 years of service.
  17. bisco
    51,140
    wow, and i thought i was old!:p i do remember the drugstore having a television tube tester though.:cool:
  18. Mendel Leisk
    40,574
    I remember when the used oil disposal was this rock outcrop behind the gas station. :(
  19. GregP507
    3,002
    481
    Reminds me of the one time Uncle Mike (he was a lot like Uncle Buck) came for a visit and changed his oil in our yard. He said afterwards, "You guys always just dump the oil on the ground, right?"
    Nope.
  20. Mendel Leisk
    40,574
    And mop up any spills with a handy bald eagle.
