Engine block heater recommended wattage
Discussion in 'Generation 1 Prius Discussion' started by cabral255, Nov 1, 2011.
  1. cabral255
    cabral255 Junior Member
    2002 Prius
    Is a 200 watt heater strong enough?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    probably not. The standard EBH for the Gen II and Gen III is 400W and is custom fitted right into the block itself--thus transmiting the majority of it's heat directly to the engine block.
    Even so, in the colder parts of winter it only gets the starting ICE temp up to about 120F. I don't think 200W, particularly if it's an aftermarket slap it on the outside type product will work very well. also, the dip-stick warmers are frowned upon by many.
  3. trseven
    trseven Junior Member
    58
    Council Bluffs, Iowa
  4. Mendel Leisk
    42,038
    Toyota apparently thinks so now, got our previous, 400 watt block heater replaced due to recall, concerns about fire risk: new one is definitely less effective. Even 4 hours plugged in, coolant hose in vicinity of EGR, that used to get very warm, is tepid.
