engine block heater
Discussion in 'Prius v Main Forum' started by ivanhoe, Apr 21, 2021.
  1. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Hi folks, I'm a new owner of a 2015 Prius V v! There' no engine block heater and I will need one next winter. The dealership has them but at twice the price from other sources. I've found KAT 11813 and Temro 3100129 but listings only show up to year 2014 or something like that. I know the engine is the same from 2012 to 2018, some minor modifications in the latter years like piston rings. Does Toyota have copyrights for a X-mount of years back and that is why the other sources only show up to a certain year. The above mentioned block heaters, would they fit in my 2015 is the question? Thanks in advance and lucky to be on this Prius site which has a vast amount of information & knowledge!
  2. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    I gather there isn't too many V owners in the colder climate :(
  3. RAM v
    RAM v Junior Member
    72
    St. Paul, MN
    2014 Prius v wagon
    I am one of the Prius v owners that lives in a colder climate (Minnesota, down to -20 degrees C or F most years.)
    I have been using the Toyota block heater for several years now. Everywhere I looked on the internet says they should fit your 2015 (mine's a 2014). Makes a big difference in how soon you get warm enough so it will run electric instead of gas engine. I usually run mine for 1-2 hours.
  4. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Thanks for reaching out. I know Toyota uses the third party heaters, just trying to find the less gouging alternative. Can you point out the one you found or is it the same one I posted?
  5. Mendel Leisk
    41,860
    I would stick with the Toyota part. I just replaced mine, connection at the heater core shorted out. Replacement looked pretty much the same, except wiring a bit different and revd part no. It was $80~90 (CDN) as I recall, through (CDN) dealership parts dept.
    How much is “twice the price”?
    for some weird reason US dealerships seem to have a hard time getting this in; maybe a factor in the price. Which is puzzling: here in the west coast of Canada it’s balmy, while in the US fly-over States they’re just crawling outa snow drifts?
  6. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Toyota is $100 minus my tiny discount(10%)=$90 versus $43.52 at a online store. I'm sure Temro makes them for Toyota but are forbidden to sell the most recent years as per their contract. Same engine cylinder head as the 2012-2014 which I would think it would work into the 2015-2018 models.
  7. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    I got this info from toyotanation;
    The heaters (manufactured by PYROIL, Ltd of Canada) have shipped to Toy Associated Parts. In turn, Toy Parts has begun shipment - via some sort of allocation - to the dealers. :thumbup:
  8. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    You must have very small hands to insert the block heater, mine don't fit! Lots of room behind the engine but it's getting the hands back there is the tricky part.....#*#* Do I have to go from under the vehicle and reach up?
  9. Mendel Leisk
    41,860
    I did it from below. Helped having 3 arms and hands, and eyes on extendable stalks. :whistle:
    seriously, i found it BARELY possible, with major cajoling of adjacent wiring conduits in the way.
    dry insert first, then just back it out, apply heat transfer grease, and reinsert while twisting, to avoid scraping all the grease off or getting it all over everything.
    Toyota has made this component easily installable at the factory, with the engine out of the car. If retrofitting, it’s very awkward.​
    #9 Mendel Leisk, Apr 30, 2021
    ivanhoe likes this.
  10. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Thanks for pointing to the right direction, this will save me time & frustration :whistle:
    I did a 98 Corolla, 11 Scion TC & a 14 Prius C before this one, should be easy I say :D
    Find the hole and insert, what's hard with that :eek:
    Yep, Toyota messed this one on us :censored:
    Now to go find a third arm....................:cool:
  11. Mendel Leisk
    41,860
    I had a few conduit brackets unbolted, cords tied around cables to pull them back as much as possible. Then from below, with splash shield removed, an arm reaching up on either side of drive shaft, could just fight the thing in, with protracted repositioning and pushing. Absurdly tough, and purely by touch.
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    You're up early, and I was by a hour :whistle:
    I could see the TOUGH part ahead of time :( but I'll manage with persistence :)
  13. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Slowly figuring out the chore ahead of me to get the heater installed. I was looking at the wrong place all the time. The previous cars I installed the sleeve type heater was into the head cylinder, not into the block itself. More progress to be done on this install in days ahead....
  14. Mendel Leisk
    41,860
    There’s a Toyota PDF on the install, and some owners have published a pretty good how to.
    ivanhoe likes this.
  15. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    I've found this pdf file for the installation and I've gotten the block heater installed and ran out of time to finish today. I tried it out and the engine block heater access mold came hot within seconds :) I'll be fabricating a metal screen for the air inlet to make sure no rodents find a new home (y) Lot's of debris of leaves helicopters resided in the cowl (n)
  16. Mendel Leisk
    41,860
    Yeah that’s the one. It doesn’t really address what a pain it is in practice, but it does help. I just ran the cord out to lower front grill, DOUBLE zip-tied securely, a few inches apart. You don’t want it dragging down the road when you forget to unplug; which is too easy to do.
    That’s good. In the front I screened the cabin air inlet, that’s on the passenger side of firewall, unfortunately requires wiper and cowl removal. @NutzAboutBolts shows the removal step-by-step in their spark plug change video (thread with links pinned in3td gen maintenance forum).
    Another item I decided to screen was the engine air inlet, thinking they may want to take up residence in the engine air filter box.
    another possible cabin egress is the hybrid battery air exhausts, at both rear corners below hatch floor. Haven’t done anything with that yet, mainly because it’s awkward, not sure of best approach, or if it’s even doable.
    #16 Mendel Leisk, May 10, 2021
    ivanhoe likes this.
  17. ivanhoe
    ivanhoe Member
    67
    27
    2015 Prius v wagon
    Finished the job, cabin air inlet w/screen and engine air inlet w/screen :)
    Road test later today....
