Engine Block Shakes Violently!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ePRIU$, Mar 30, 2021.
  1. ePRIU$
    ePRIU$ Junior Member
    35
    My Prius 3 engine block shakes violently and knocking metal sounds bad, it seems like the engine block is about to jump out. I shut the engine off, give it to 10 seconds then it starts up normally. This happens rarely once very several months.
    My Prius is driving fine, idling easily and mileage is very good. YouTube has so many suggestions like blown head gasket, EGR valve, bad spark plugs..
    Any Prius owner had this experience and fixed (DIY)? I need to be proactive to take care this issue, my Prius has 160K, thanks.
  2. Mendel Leisk
    38,709
    Has Exhaust Gas Recirculation circuit and intake ever been cleaned?
    Raytheeagle and ePRIU$ like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    If it only does it once in a while at first startup then...
    Shock and Awe
