Engine Brake Q...
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Whiteyprius, Feb 8, 2018.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Q for those of you that drive often in mountainous areas ... In my 2017 trim two, I often use the engine brake while descending a long hill, after the battery is full . Then when I shift back to drive and let off the gas, the engine sounds and feels like it is at least partially in engine brake mode. After several miles, things feel normal again. Any similar experiences? Thanks!
  2. padroo
    padroo Senior Member
    2,763
    2,252
    I haven't driven my new Prius in the mountains yet but don't remember my Gen 2 doing that. It just started coasting until I hit the gas.
    RCO likes this.
  3. Whiteyprius
    389
    105
    North Carolina, USA
    What I described never happened with my Gen 2 or Gen 3.
    Sent using Hello Moto
  4. mark27lim
    mark27lim Active Member
    108
    104
    singapore
    i have similar rxperience. i think the computer is just doing its thing and being extra smart
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, I'm told that's what it's designed to do to stop over-charging (and overheating) the battery. With Gen 4, "B MODE" is entered automatically going downhill after the battery is full. The kinetic energy from going downhill has to go somewhere once the battery is full, so it spins the engine, that's instead of wearing out the brakes.
    There have been several threads on this.
    RCO and kithmo like this.
  6. Whiteyprius
    389
    105
    North Carolina, USA
    I understand. But this occurs after the battery indicator has dropped a bar or two. Do you think the car hasn't decided to accept charging quite yet?
  7. alanclarkeau
    7,045
    7,593
    No idea - just an idiosyncrasy - someone put a sophisticated metering on it, and I think came to the conclusion that it's in "limbo*" for a couple of minutes till the battery temperature stabilises after a rapid charge.
    *limbo - a technical term which escapes my understanding.
    RCO likes this.
  8. Prodigyplace
    12,660
    11,827
    Central Virginia
    That could be the case if the battery needs to cool further before safely charging. How long have you had the car? How many miles?
    Is this a recent change? If so, check the hybrid fan vent on the lower rear passenger seat. The manual says to just vacuum the grille, but if you remove it you can see a filter in behind that too. If that vent gets clogged with pet hair or other debris, the cooling fan needs to work harder and traction battery can get too hot.
  9. alanclarkeau
    7,045
    7,593
    I tried checking mine when it first happened - and it was clean as a whistle, but check that nothing is over the vents. The main one is the one on the corner of the rear seat (left of the photo), we're not absolutely certain what the vent in the middle is (right in the photo), but I make sure it isn't covered.
    RCO and Prodigyplace like this.
  10. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Are you sure about this? I don't see it mentioned in the Owner's Manual. I think you still have to place the shift lever in "B" mode, it's not automatic...
    RCO likes this.
  11. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    When descending a hill with cruise control on, the prius will maintain the speed the cruise control is set at, the engine brake can be heard, I prefer to let the computer control my speed when going down hill, and uphill and on the flat.
    The Gen2 manual warned about to much use of the (B) lever, I notice my Prime Advanced uses the engine brake frequently.
    I prefer to maintain the speed limit.
  12. Prodigyplace
    12,660
    11,827
    Central Virginia
    The same thing happens with Gen 4, even if it could charge the battery. On my trip to work I turn off cruise on the small downhill and brake manually to recharge the battery instead of wasting the energy.
    RCO likes this.
  13. Whiteyprius
    389
    105
    North Carolina, USA
    Thank you so much for bringing up the battery-cooling issue. I've had the car for several months and haven't noticed until looking for it today that the vent moved location for Gen 4 - And guess where I chose to put my little trash bin??? Right in front of the vent (that I didn't realize was there!) Thank you all for helping me to figure that one out!
  14. Prodigyplace
    12,660
    11,827
    Central Virginia
    I looked after somebody else mentioned the filter behind. It is surprising the manual does not mention cleaning or replacing that. @Elektroingenieur is the cooling fan filter easily replaced on Gen 4?
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I may be wrong but I don't believe the HV battery indicator is all that accurate TBH.
    alanclarkeau likes this.
  16. alanclarkeau
    7,045
    7,593
    I suspect not too - particularly at the top of the range. It's just an indicator. Like the EV light which lags often.
    Bear in mind that the battery WON'T go below about 20% and above 80% anyway, the HV indicator only theoretically utilises the area between. I've never noticed mine get as low as 1 bar, and only a couple of occasions has it got to the very top bar (after long downhill section).
    kithmo likes this.
  17. Elektroingenieur
    2,515
    3,287
    Three Touring
    The symptoms aren’t quite the same as those @Whiteyprius describes, but since he has a Prius Two with the NiMH battery, I wonder if it might be worth asking a dealer to do the HV ECU software update described in T-SB-0241-17, if it applies. This addresses other concerns “after repeated driving on long downhill slopes.”
    It does—for MY 2017, pages 83, 88, 573–574, and 667.
    Yes. The Owner’s Manual gives a procedure only for vacuuming the No. 1 HV battery intake filter in place, but removal is not difficult. The Repair Manual says to remove the battery service hole cover (a clip, then five claws) and the filter (a claw, then two more claws) and then clean the filter with compressed air or replace it. The part number is G92DH-47070; list price $11.35.
    RCO and alanclarkeau like this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Australia obviously lacks the switchback dipping and winding roads of Cornwall! :ROFLMAO:
  19. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    Going downhill, when the battery gets full on my '19 awd-e the ICE starts to rev higher, but B-mode make it rev a lot higher.
    FuelMiser likes this.
