Engine Brake?
Discussion in 'Gen 2 Prius Main Forum' started by exces6, Aug 23, 2004.
  1. exces6
    exces6 New Member
    97
    Houston, TX
    Can anyone explain to me what the Engine Brake (part of the shifter) does? Does the engine shut off?
    Thanks in advance.
  2. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    It is used for downhill grades where you would need to ride the brakes to keep the car from gaining speed. Effectively it uses engine compression to slow the car. As a benefit of the HSD technology, it generates electicity for the traction battery at the same time. On a steep grade, you might end up using both B and the brakes. In a situation where you would shift into B, the engine would already be off..
  3. exces6
    exces6 New Member
    97
    Houston, TX
    Wow. That was fast.
  4. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    I used the heck out of it driving to Michigan from California. You know when the road is a steep downhill and you see those "Use Lower Gear" signs along the road? That's when you flip it to the "B" position, just as if you were downshifting in a more primative automobile.
    The brake lights don't come on in the B mode, also.
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    In my recent trip over 4 western mountain passes I used B mode intermittently. I would let the car coast to 5 over the speed limit and put it in B till I was 2 to 4 under then put it back in D and repeat the process. I would love to here of comments from those more experienced with the car. This mimics what I did with a conventional car when second gear slowed the car a bit much. The B setting does a good job even on a fairly steep grade.
