Engine break-in period?
Discussion in 'Gen 4 Prius Main Forum' started by FuriousPrius, Nov 23, 2021.
  1. FuriousPrius
    FuriousPrius New Member
    2022 Prius
    How long is the break in period for a brand new Prius? Mine just hit 5,000 miles, and I'll be honest, there were times where I absolutely floored it. Will this hurt the engine? Does the fact that the engine may only have ran for maybe 70% of those 5,000 miles also prolong the required breakin period?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Just drive it.
    READ THE MANUAL!!!
    Tyres generally needed 100 miles to bed in before high speeds.
    Brakes, the manual says 200 miles.
    Manual says about engine - For the first 1000 miles (1600 km)
    • Do not drive at extremely high speeds
    • Avoid sudden acceleration
    • Do not drive at a constant speed for extended periods.
    The rest of the car - nope.
    Doug McC, jerrymildred and Tyfly like this.
  3. orangecones
    orangecones Member
    46
    28
    NZ
    ^ - basically that. As long as for the first 1k miles you didn't flog it too hard, or did a steady state 65 mph highway run to the next state and back, you're fine. After 5k - just drive the damn car already.
  4. 228Prius
    228Prius New Member
    Gulf Coast, MS
    2022 Prius
    The manual actually says 1000km as per my recollection of the 2022 Prius manual. You are good to do as you wish.
    Doug McC likes this.
  5. vvillovv
    vvillovv Senior Member
    3,607
    1,271
    NY
    Are you asking about a 2022 Prius? or a 2022 Prime LE trim?
  6. Mendel Leisk
    38,648
    Yeah, second this. Anyway, visual aid, page 210 of 2016 Prius Owner's Manual, in the glove box, and/or available for download as a pdf:
  7. ETC(SS)
    6,542
    Hate to break it to you pal, but when you "floor" most modern cars you aren't "flooring" it at all, but rather you're sending a request to the engine room for more power, since Priuses (like most cars now) are 'fly by wire'.
    Besides, with the tractor-like rpm of the Priuses, it's not like Wide Open Throttle starts are going to over-rev an Atkinson mill anyway.
    One can (and I have) put a brick on the accelerator pedal of a Prius....go inside. Drink a cup of coffee, and come back outside, and you will not have "hurt" the car at all.
    Much.
    DON'T EVER buy a rental car ro fleet vehicle. :D
    Humans do not build engines these days, Robbie the Robot does.
    They are are fully tested at the plant before Robbie's cousin, Robbie puts it into the not-yet-a-Prius in Aichi Japan...or wherever they build them today.
    RTFM.
    (Read the.....er....Factory Manual)
    Lots of good info in there....especially in the Warranty and Maintenance guide, which is core and key to saving even more money at the repair shop than the Prius will save you at the pump, which is something that many new car drivers get completely wrong.
    You don't have to know HOW to do the maintenance, just WHAT needs to be done and when.
    There is value to doing what the manual tells you to do, but in the end Priuses are built to a specific life cycle, which seems to be something in the neighborhood of 20 years and 250,000 miles.
    Most people who but 'break-in' miles on their car will bail out in the front nine.
    Priuses are OEM warrantied out to a maximum of 8y(?) and 125,000 miles which means that THEY are betting their money that the car will not require major work before then no matter HOW you treat the car.
    Good Luck!
    douglasjre and alanclarkeau like this.
  8. alanclarkeau
    7,044
    7,584
    I copied that out of a US 2019 Manual.
  9. FuriousPrius
    2022 Prius
    ok I see. I'll take a look at the owner's manual as well.
  10. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    I refer back to my owners manual quite often. So much technology, and who can remember what all is on those 740 pages. And then there is the Navigation manual...
    jerrymildred likes this.
  11. Mendel Leisk
    38,648
    PDF version of the Owner's Manual can be easier to find things in; searching for text strings beats thumbing through the paper tome. Toyota Tech Info's the site I get them from; there's another site also offering the manuals, saying "Toyota Owners", something like that?
    AzWxGuy and alanclarkeau like this.
  12. orangecones
    orangecones Member
    46
    28
    NZ
  13. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    ALWAYS a marvelous place to start when buying a new piece of equipment.
  14. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    Still for the life of me don't understand what's wrong with opening the throttle on a new car especially since that's what has to be done with a brand new engine to get the rings to seat before the sharp edge dulls off of them
    Pulse07 and alanclarkeau like this.
  15. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    A friend of mine says. "A good one it won't hurt; a bad one it doesn't matter"
  16. Doug McC
    997
    374
    Midwest
    2022 Prius
    It’s also a great way to effect whether you end up with a good one or a bad one, but, I just had this thought, maybe your friend is referring to the owner? ;)
    Ryder99 likes this.
  17. alanclarkeau
    7,044
    7,584
    I have a friend, who, back in the time had a MINI Cooper "S" - the original one.
    He had the engine rebuilt, balanced, blue-printed.
    And to run-in, ran the engine at full throttle on a hard uphill at the engine-builder's instruction.
    I believe that car is still running today - 50 years later.
    BUT - what will work for an English OHC engine - could be very different to a PRIUS DOHC, VVT etc - and driving through a Hybrid Synergy Drive - which will preclude that sort of driving. And oils are dramatically different. And engines are made to much tighter tolerances. They generally last much longer too - and in the case of a PRIUS - if mine says it's been 34% EV - that means the ICE is having a break regularly.
    They say these days - just drive it.
    AzWxGuy likes this.
  18. Mendel Leisk
    38,648
    One factor a lot of the manufacturers stress for break-in, is to vary rpm and load, which isn't hard to do; just avoid droning on for 100's of miles on an isolated highway with cruise.
    Doug McC and alanclarkeau like this.
  19. Pulse07
    Pulse07 Active Member
    273
    139
    East Bay, California
    2020 Prius
    XLE AWD-e
    The Prius jumps form 0 to 5000 rpm because of the hybrid drive train. If im cruzing at 55mph on electric mode, hill that hurt the ICE during break in period?
  20. douglasjre
    1,858
    647
    Orlando, FL
    And for the life of me I cannot understand why one RPMs makes a difference from varying it. How did the metal parts know any different
