Engine Check light keeps going on and off?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Takaaaa, Feb 23, 2011.
  1. Takaaaa
    Takaaaa New Member
    32
    Hawaii
    So recently my engine check light has been going on and off... Not blinking but it will stay on for a few hours then turn off for a day or so. All the times on and off are different. When I go to get the code checked it turns off... as I leave and get home it turns on.
    Anyone have this problem??
  2. richard schumacher
    7,663
    1,040
    United States
    Start with the simple cheap easy stuff: Is the gas cap not on tight? Is it broken?
  3. Takaaaa
    Takaaaa New Member
    32
    Hawaii
    Yeah I checked if the gas cap was on tight or if the battery was properly connected but still keeps turning on and off. Ill try time it again and see if I can find out whats wrong. Normally it turns off when I go get the code read...
