engine check without reason
Discussion in 'Gen 2 Prius Main Forum' started by Vanne, Nov 25, 2012.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    last night is heavy rain , i drive across the rain, and my friend he open the car door and have some rain drop in my car and i drive across the road that have flooding a bit , this morning i have engine check light appear on my car , what happen to my car ? please help help
    thanks for helping me
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Do you have any way to have a mechanic connect an OBDII diagnostic code reader and tell you what the code indicates? If you can tell us what the diagnostic code is we can better help you.
    A Check Engine Light is not as serious as a Red Triangle.
  3. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    thanks you for your prompt reply, i didn't have OBDII if i want to do so i have to bring my car to dealer and it will cost me , anyways you have any clue about what is going on with this kind of warning ? because of water reach to the computer system or ?thanks you again for your help
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    My guess would be that an electrical connector got wet. The OBDII code reader would help indicate what sensor is not working properly.
    In the US most any auto mechanic can read the Check Engine Light for you. It does not have to be a dealer.
    If it is more than just a CEL then it may require the dealer to diagnose with a Techstream computer.
  5. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    thanks you for your advise i will ask local technician to check and reply the code to you, or i will post in the forum for help, thank you very much
  6. Patrick Wong
    18,200
    6,479
    It would help if you could determine the DTC logged by your engine ECU. However if it is not possible for you to obtain the DTC and you don't mind guessing about the cause, I would say the most likely reason is that rain water had dripped down from the windshield cowl area onto the engine valve cover. From there, water has gotten into one or more spark plug wells in the cylinder head.
    To check that, you would have to remove the four spark igniters and use a mirror to look into each spark plug well. If you don't see any water, remove each spark plug and inspect for rust on the threads which would show that water was present.
    Also inspect each spark igniter plastic body for cracking, burn marks or rust stains. If you see any problems then the igniter should be replaced.
    If you find that water is the problem, you should use sealant on the vertical seam that runs along the middle of the windshield cowl black plastic to reduce the likelihood of a future water leak. Good luck.
