Engine clatter on startup
Discussion in 'Gen 3 Prius Main Forum' started by Lakerat, Oct 4, 2020.
  1. Lakerat
    Lakerat New Member
    Sherman, texas
    I have a 2014 Prius base model that has a startup engine knock to address this I replaced the coil packs, sparkplugs , and injectors t were professionally cleaned and I still have a startup engine knock I am stumped with this problem any help will be appreciated. Thanks
  2. tvpierce
    tvpierce Senior Member
    941
    861
    Maine
    2013 Prius v wagon
    Welcome.
    Search "misfire on start up" and you'll get losts of reading. Clean the entire EGR circuit (cooler, pipe, valve, and small ports in the intake manifold), install a oil catch can, and see if that helps.
    scona likes this.
  3. taxidriver50005
    101
    GB
    Excel
    Does it rattle every start up or only acationally
Loading...
