Engine Cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Jul 10, 2021.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Nine years and 152,000 miles later, after giving this engine the Purple Power/Armor All treatment every six months or so…
  2. Tideland Prius
    16,146
    Nice! Very clean. Did you use a hose to get the loose grime off or just purple armor?
  3. Rebound
    3,964
    2,613
    Portland, OR
    Yes, of course you must rinse off the Purple Power! The engine is aluminum and PP will corrode and eat into the aluminum if soaked in the stuff for hours. But spritz on, wait 15 minutes, hose off? No problem. And no problem if small traces remain.
    Beyond that? For sure, several times I’ve scrubbed the engine with a brush (which you can’t really see in this photo). I’ve taken the whole air box out a few times and completely cleaned it. I’ve taken the windshield wiper motor tray out and totally cleaned all of that to the firewall — I want the cabin air intake to be breathable air, not moldy tree sap and bird poop. But those kinds of cleanings have been a few times in the car’s nine year life, not annually. The wiper tray cleanings were done with maintenance, not on their own.
    #3 Rebound, Jul 10, 2021
    Tideland Prius likes this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,962
    4,709
    Texas Hill Country
    Pretty nice. I would add the wire cover here:
    privilege and Mendel Leisk like this.
  5. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Hope engine starts after
  6. Mendel Leisk
    38,708
    More info:
    Question in engine compartment | PriusChat
    @Rebound, when you've got the air box and snorkel out, disconnect the 12 volt connector (black, not orange) from top of AC compressor, and hit the connector atop the compressor with some compressed air (even just a decent bulb blower), to ensure there's no water trapped. There's been more than one report, someone had a wash and end up with corroded connectors there.
    It's tricky to release the connector; I found a pen knife blade on the front side, virtually right at the bottom, and pried out gently, will help immensely, makes it easy to release.
  7. Rebound
    3,964
    2,613
    Portland, OR
    FINE!! I give up, ok? I quit!
    I’ve had those wires exposed for nine years, and every time I show off my clean engine, it’s the same thing: “Hey, you ought to cover those wires.”
    It’s Official: I ordered the thing.
    Now I have to decide if I want to pull my air box out. Maybe after I buy a can of compressed air, since I don’t have the machine here.
    privilege likes this.
  8. Rebound
    3,964
    2,613
    Portland, OR
    Of course it will start. I don’t spray water into the air intake, so why wouldn’t it start? The electrical connections are all sealed. I’ve done this many times without any trouble. Maybe if your engine is in bad shape and the fuse box cover is cracked? But I’ve never had any problems doing this.
    Not to be a dick, but… you understand these cars depend on airflow to cool the radiator and engine, so when it’s raining, water enters the engine bay. The engine is sealed against that, as long as water isn’t sucked into the air intake. But the resonator on a Prius is designed to let water fall right out before getting sucked into the engine. And the apron below the engine is not water-right and doesn’t need to be.
    Grit likes this.
  9. ASRDogman
    ASRDogman Senior Member
    6,085
    3,271
    Those wires get expoxed to water everytime it rains. Rain water gets into the engine compartment.
    First time I saw mine I thought a cover was missing. Then realized it wasn't.
    It just looks out of place to me since you have the other covers.
    If others are so worried about it, let them buy the cover for you. (y)
  10. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "If others are so worried about it, let them buy the cover for you."
    Indeed. Give the man a break; he is obviously fastidious, or he'd be dead in the water (no pun) by now...
  11. Rebound
    3,964
    2,613
    Portland, OR
    [mention]Mendel Leisk [/mention] Exactly! I’m being persecuted. The part was $12 with shipping; chip in! I accept PayPal and Molson. Mostly Molson.
    #11 Rebound, Jul 11, 2021
    Grit and Ed Beaty like this.
  12. Mendel Leisk
    38,708
    I was talking about the AC 12 volt connection, and it’s propensity to catch water, corrode/short, and possibly lead to compressor replacement.
    but yeah, I also did that ECU wiring cover, was $5~6 through Amayama, plus maybe $10 for shipping. Getting some filters or wiper blades might make the shipping more worthwhile.
  13. ASRDogman
    6,085
    3,271
    I'm not chipping in! It's a needless part, and not for MY car! :cautious:
  14. ChapmanF
    15,567
    Well, I also noticed the plastic cover some add over the inverter ... but not the one over the coolant bottle. :D
  15. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :cool:
  16. ColoradoBoo
    ColoradoBoo Senior Member
    962
    630
    Monument, Colorado USA
    Wow, looks great! I work on cars so when I clean out my engines I just take dirty stuff right out and clean it with Simple Green outside. With all the electronics in there, no way I'm spraying water. For stuff I can't take out, I have a little vacuum and little brushes I use to suck up as much as I can. Then I use those heavy duty Miracle Wipes. Some cover their engines with plastic and use the hose on the inside of the hood and side areas but mine haven't been THAT dirty. (Yet.)
    If anyone is going to be spraying water on their engine, PLEASE first disconnect your negative battery terminal and let it dry for hours (better yet, overnight) before reconnecting. Not too many things worst than have an electrical issue in modern cars. (I believe the Prius has 53 computers.)
    tankyuong and Mendel Leisk like this.
  17. Rebound
    3,964
    2,613
    Portland, OR
    Come one, the GoFundMe is getting started, I only need you to kick in 83 cents.
  18. Rebound
    3,964
    2,613
    Portland, OR
    I live in Oregon. I promise you, that engine gets wet.
    kc410 likes this.
  19. Rebound
    3,964
    2,613
    Portland, OR
    I have corrected my misdeed of naked inverter wiring. As you can see, I replaced the inverter coolant while I was at it.
    Mendel Leisk and Steph1972 like this.
  20. Rebound
    3,964
    2,613
    Portland, OR
    They are completely different.
    It’s like this:
    The Inverter Cover adds a touch of luxury and class.
    The Coolant Cover adds a touch of “I’m a pimp.” Which is ok; I’m not judging anybody who’s into that profession, although, I’m not sure Prius is the chosen vehicles of those in the business.
    In all seriousness, the inverter has aluminum parts which oxidize. It’s impossible to keep it looking like new, unless maybe you powder coat it. On the other hand, the coolant cover simply covers a piece of plastic with another piece of plastic. Worse yet, it makes it harder to check the coolant level. So I’m not a fan.
