engine codes, p3105, p3115
Discussion in 'Generation 1 Prius Discussion' started by krystalstorm, Oct 29, 2015.
  1. krystalstorm
    krystalstorm Junior Member
    coatesville pa
    master warning light came on, i turned the car off and the engine would not start again. it had engine codes p3105 and p3115. the p3115 is the code for the main relay, even with the chilton manual i cant locate the main main relay. also the hybrid battery is dead. can anybody tell me where the main relay is? if and how to charge the hybrid battery? and any other advice on this issue
    i have had the car for less than a year, its my mechanic who is doing the work, he knows alot about cars,he just dose not know much about hybrids, i also have a parts car working hybrid battery and all. so parts isn't the problem; diagnostics is the real drama. thanks for the tech info but what are the odds that its the battery as opposed to something else?
    #1 krystalstorm, Oct 29, 2015
  2. ChapmanF
    15,719
    Any chance you could add some details? How long have you had the car? How long would you like to have the car? What's your overall background in working on cars, or in working safely around typical Prius voltages (around 300 volts)?
    For any serious work around a Prius, I'd say lose the Chilton's. The factory manuals can be downloaded from techinfo.toyota.com on a $15 subscription, and unlike the fakebooks, they will actually tell you stuff you need to know about your car. In particular, when you look up your codes in the manual, they will have page numbers next to them, where you will find whole troubleshooting procedures you can use to home in on the problem.
    The relay you're referring to is inside the main battery case, and that's a high-voltage environment even when the car is off. If you look at absolutely nothing else (which I don't recommend), at the very least, see if you can search up a copy of the "SSC 40G" battery service campaign instructions. (Not the short announcement letter, the instructions, about a 56 page pdf.) They will give you a good overview of working inside the battery and how to do it safely.
    As for how to reconstitute a dead or dying battery, in cases where that might be possible, there are a lot of threads in this forum about that, and you'll probably find a few hours finding and reading those to be time well spent.
    Good luck,
    -Chap
    Meg&Bear likes this.
  3. bwilson4web
    15,533
    Let me suggest:
    1. Disconnect 12 V battery (the ground wire)
    2. Measure 12 V battery voltage:
      1. 12.85 V - perfect, 11.9 V usable
      2. < 11.9 V Uh OH! put on charger
    3. Connect 12 V battery and try to start car
    Now you can begin problem diagnosis. Without a good 12 V battery, nothing is to be trusted. Disconnecting it for 30 seconds wipes all code. When you try to start again, we will get the current, fresh codes. This is where we start.
    If car starts, measure the running 12 V. If it is 13.8-13.9 V, the 12 V circuit is charging and we can begin running car diagnosis. If it does not start, we can begin non-running car diagnosis.
    We'll wait till you get there.
  4. Patrick Wong
    18,200
    6,479
    DTC P3105 means a communications error between the traction battery ECU and the hybrid vehicle ECU. As you know, P3115 means a problem with one of the three system main relays located in the traction battery enclosure.
    As previously suggested, you or your mechanic need to subscribe to techinfo.toyota.com to obtain factory repair manual info to help you address these problems.
  5. bwilson4web
    15,533
    With respect, I agree with Patrick after the 12V system is checked. A marginal 12V circuit can cause a lot of misleading codes. Once we see solid 12V, read the codes and follow the Toyota fault-code instructions in Volume 1.
  6. krystalstorm
    coatesville pa
    hi again, so we did everything that was recomended and switched out the whole relay case that was attached to the hybrid battery and nothing changed. still have the p3115 and p3105 and the car powers on but will not go into ready mode
  7. ChapmanF
    15,719
    When you say you "did everything that was recommended" does that mean you really did look up your codes in the real manual and follow the specific testing and troubleshooting steps there?
    One of the hardest notions to get across to newcomers is that when the car's computer gives a code x and you see a one-liner code listing that says x means system main relay, that does not mean the computer is telling you to change the system main relay.
    All it means is, the computer is telling you that somewhere in its entire control and monitoring feedback loop involving the main relay, something isn't right. Your mission is to find out what isn't right in that whole subsystem, then fix it. The troubleshooting steps in the manual will be invaluable for that.
    -Chap
    Meg&Bear and bwilson4web like this.
