engine codes
Discussion in 'Gen 2 Prius Main Forum' started by misterdean, Aug 20, 2024 at 8:45 PM.
  1. misterdean
    misterdean Member
    187
    28
    FL
    the auto part store told me it could be several things. how would i go about narrowing in on what my issue is? not sure if relevant, but i've always had a tire pressure light on, when the engine light came on, the tire light went off. i noticed the center display is no longer displaying the mpg bars. also noticed this other light that i've never seen before. pics attached.
  2. Tombukt2
    Tombukt2 Senior Member
    9,558
    1,674
    Durham NC
    You need to change your inverter coolant pump to get the red car off of the MFD center display The pump is behind the driver side headlight if you put your hand on it with the car ready it should be humming and you should see a little bit of movement in the reservoir between the engine and the inverter that says hybrid synergy drive If you see no movement but you feel vibration probably time for an inverter pump by the real Toyota one so you don't do it again anytime soon I know the $39 one seems tempting but they fail as fast as you install them so be ready to do it often The PO420 if you have a missions in your state then you may need a spacer with a swivel made out of stainless steel that has a piece of converter material in the end of it they make these they're about $18 that may get the light off for you If not you're buying a very expensive catalytic converter like 12 or $1,400 seriously where I live I don't have to pass emissions so we don't have to do anything with that your city or town may be different
  3. Tombukt2
    9,558
    1,674
    Durham NC
    In Florida I don't think you have anything down there You can do anything you want with your vehicle so you can just leave that light alone I have one or two here that I've had that code for 5 years they still get excellent gas mileage and everything this has nothing to do with anything except the catalyst being below threshold of some computer setting that is probably set too tight to begin with anyway It's nothing we can change AE11 Corollas had this exact same problem more or less it was an ACDelco firmware problem for the computer between the 2 02 sensors
  4. misterdean
    misterdean Member
    187
    28
    FL
    is the auto part store full of shit telling me it could be several things? was kinda hoping it could be a sensor.
    what does the inverter do exactly? wondering how this will effect the car and if i shouldn't drive it until fixed. does this effect the AC? any chance one of these issues could be effecting the other. i find it strange both lights came on at the same time.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,320
    5,996
    Columbia, SC
    The P0A93 code is showing there is a problem with cooling of the electronics (the inverter, located in the engine compartment). That code has two possible subcodes, one that points to the pump being a problem and one that points to the cooling fan being a problem. 95% of the time, the problem is the cooling pump failing. That pump is located directly behind the driver headlight.
    The inverter converts DC power from the HV battery into an AC waveform. This AC is used to power the transaxle and also powers the AC compressor. When the inverter loses cooling, it tries to protect itself. One of the first things is will do is stop powering the AC compressor, so intermittent operation of the AC is one of the first signs of an inverter cooling water pump failure.
    Drivability of the car depends on weather conditions. I've driven a Gen 2 with a failed inverter pump 40-50 miles at 45mph in cool weather and never had a problem. Drive faster (more load on the inverter) or during hotter weather, or with AC blasting and the inverter may have temperature problems. It will protect itself and once it gets warm enough, will code out and put the car in a safe mode until it cools sufficiently. Short, low speed trips are usually not a problem. Highway speeds will make it code out within 15 minutes.
  6. misterdean
    misterdean Member
    187
    28
    FL
    wasn't sure if it was in my head or just hot today but it did seem like the AC was not as cold as it should be. sounds like don't worry about causing damage to the car just don't use the AC for now.
  7. TMR-JWAP
    6,320
    5,996
    Columbia, SC
    I would definitely not run the AC, to maximize driving time. The inverter temps are usually ok for short low speed trips, but the amount of heat generated by the inverter directly depends on how fast you drive, how far you drive and outside temperature. If it does overheat, it will code and put you on the side of the road for an hour while it cools off. Once it cools some, it will let you drive again. Obviously, this is not the ideal way to treat the electronics, but if you need to get around, you need to drive, right?
    There's many threads on the forum about this pump. It's the inverter cooling water pump and is available from Toyota dealers for about $130. Counterfeit versions are also available for $50, but how long they'll last is anyone's guess. Takes about 2 hours or less to replace if DIY with no prior experience.
  8. misterdean
    misterdean Member
    187
    28
    FL
    understood.
    the inverter pump is vibrating in accessory mode. the reservoir is not. when i opened the reservoir to look inside i can see the fluid moving. since the inverter is vibrating, and the fluid is moving, should i look at the fan? where is it? i tried to search for inverter pump fan but wasn't getting any hits. assuming i'm using the wrong key words.
    whats your opinion on the catalytic converter code? 100% it needs to be replaced or could it be a sensor or something else?
    #8 misterdean, Aug 21, 2024 at 2:26 AM
