Engine coolant level...
Discussion in 'Gen 3 Prius Technical Discussion' started by unigeezer, Sep 6, 2024 at 1:06 PM.
  1. unigeezer
    unigeezer Member
    222
    59
    torrance, ca
    If the engine coolant reservoir is a little bit below the full line, when the engine's cold, should I top it off to the "B" line, or do you do that only after draining and refilling?
    #1 unigeezer, Sep 6, 2024 at 1:06 PM
  2. burebista
    burebista Active Member
    175
    116
    Romania
    AFAIK "B" line is only for draining and refill.
  3. ChapmanF
    15,940
    Only as part of the refilling process after draining. It should end up at FULL after it has traded places with the air in the system.
    49,752
    How many miles?
    Egr circuit been cleaned?
    Keep an eye on the coolant to make sure the head gasket isn’t blown
  5. unigeezer
    unigeezer Member
    222
    59
    torrance, ca
    90k. And there is no way in hell that I would even attempt to pull that EGR valve out and all the work involved doing it! Especially if it's not showing any symptoms of being clogged or dirty.
    #5 unigeezer, Sep 6, 2024 at 4:18 PM
  6. bisco
    49,752
    I felt the same way, and traded it in when it started misfiring
